6730c vibrate only good day to all i have a 6730c dead vibrate only when i press power button then vibrate comes then again and again when you press power button. i flash it with same product code. i reheat rapu ic but same i check bsi ok what i shall do? thanks in advance |
is mobile going into local or test mode ? r u able to check selftest ? |
http://www.forum.shaarpmind.com/atta...0&d=1353218302 http://www.forum.shaarpmind.com/atta...1&d=1353218306 |
replace pearl ic or gazoo ic |
Brother if u try all these solution then last try to take off the Headphone ic near usb jack, Post result. |
what next sir? |
i flash it in usb but phone did not recognized |
sir try to check camera flex |
this unit did not have camera flex... i remove camera but same result |
Brother your Rapuyama ic is faulty, try to shake again... |
ı same problme 6730c only vibrate phone full firmware write and rehaut double cpu but not solve |
