11-02-2001, 12:42 | #1 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | 7110 no power via switch but will power via JIC Box The phone will turn on after I press info in JIC, and will shut off via switch. But after power off, syou can't turn on using switch. You need press 'info' in JIC. After a while, phone will not power with JIC also.. You need to flash the phone before it turns on in JIC. It is not the switch. I tried using other LCD module assembly. Thanks friends. |
11-04-2001, 10:20 | #3 (permalink) |
Freak Poster Join Date: Oct 2001 Location: uk
Member: 6995 Status: Offline Thanks Meter: 0 | I have the same problem with a 6210 the phone would not power up before using on jic box and when info was pressed it read the phone and powered up,tried flashing,upgrading,down grading but still no power by button the person whos phone it was admitted dropping it I assume it fractured the board as I have attached new power switch also |
n70 power on cable but not power. | sergioems | Nokia Hardware & Hardware Repair | 7 | 01-16-2009 09:48 |
No Power Sh903 Vodafone Succesful in flashing via TP in SE TOOL but still No power | dmaetrey | SETool2 | 2 | 03-08-2008 02:40 |
L7 dead but will power on with charger connected | shawgsm | Motorola Hardware Repair | 5 | 10-15-2007 14:24 |
V3i No Keypad/Display lights but phone power up + charge | xfarenheitx | Motorola P2k | 9 | 09-11-2006 19:11 |
6310i Will charge OK but will not power ON ! ! ! ! | Fre3 Crack3r | Nokia Hardware & Hardware Repair | 9 | 09-23-2003 12:05 |
