09-16-2002, 00:07 | #1 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Slovakia
Member: 7586 Status: Offline Thanks Meter: 11 | 7110 roller not working I have 7110 , roller is not working. all everything is working without problems. I changed roller but not helped. Any idea how to fix it ? My sw. is 5.01 b.r. Pali |
09-17-2002, 02:28 | #3 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | There is a metal plate that is attached to the screw hole of the 7110 A-cover. I've encountered serveral times where this metal plate is missing. People change A-covers not re-installing this part to the new cover. This plate keeps the navi-roller contacts to the pcb. If this doesn't help. Get a working board. The 3 navi-roller contact pads have 3 jumper points on the board which connects thru board to their respective resistors and caps before going to MAD. Check the lines individually if there are any lines cut. |
09-17-2002, 03:53 | #4 (permalink) |
Junior Member Join Date: Jul 2002 Location: Philippines
Member: 13586 Status: Offline Thanks Meter: 0 | I also have a problem with my 7110. But this one jumps all over the phone book when I start to scroll. The phone works fine during the first 1 minute after that the problem starts to kick in. Other than the roller problem, the phone works normally. I checked the roller and it's contacts and they seem to be fine. Also tried flashing from 494 to 501 but no luck. |
09-18-2002, 03:00 | #6 (permalink) |
Member: 13586 Status: Offline Thanks Meter: 0 | thanks hannukah. btw, is there a way to bypass PUK1 without resorting to the unblocking code( i lost it long time ago). a repair shop here says it can be done. |
09-18-2002, 18:07 | #7 (permalink) |
Member: 5246 Status: Offline Thanks Meter: 9 | If they have contacts within globe or smart, they can get you PUK code for you for around P250 for globe. For smart PUK, go to your neares wireless center and they will gladly retrieve your PUK for around P50. |
..::5610 roller not working::.. | HUM | Nokia Hardware & Hardware Repair | 4 | 10-14-2008 21:45 |
PBB not work :( 1st day not work | todoportable | Phoenix Black Box | 23 | 08-05-2005 11:56 |
Keybord not work on 7110 | Moc | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 03-04-2004 13:23 |
nokia 7110 Speaker doesnt work | comiter | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 03-12-2003 08:04 |
7110 roller contacts | cellularM | Nokia Hardware & Hardware Repair | 0 | 01-11-2003 10:57 |
