05-22-2005, 19:55 | #1 (permalink) |
Banned Join Date: Dec 2004 Location: MX-KEY is the BEST NOKIA TOOL Age: 51
Member: 101683 Status: Offline Thanks Meter: 26 | 7200 camera on standby mod??? i have 7200 when i open camira it say fail then say camera on standby mod, what can i do ????? thankes... |
05-26-2005, 22:45 | #4 (permalink) |
No Life Poster Join Date: Sep 2002 Location: max232 chip
Member: 16036 Status: Offline Thanks Meter: 5 | camera on standby mod<-- possibility 1-> CAM unit got dirt under 2-->cam NOT making good contact to pins USE A SRT 10 n remove cam UNIT carefully with tweser CHANGE CAM unit,put new or working cam or CUT LINE vflash THEN u look at upp /uem good luck |
12-09-2006, 10:46 | #6 (permalink) |
Insane Poster Join Date: Mar 2004 Location: Nigeria Age: 47
Member: 59528 Status: Offline Thanks Meter: 0 | Please in case , i put another panel the camera worked, if put back the other panel it would be carema on standby. i suggest it has not to do with the camera alone. |
12-09-2006, 10:47 | #7 (permalink) |
Member: 59528 Status: Offline Thanks Meter: 0 | Please in my case , i put another panel the camera worked, if put back the other panel it would be carema on standby. i suggest it has not to do with the camera alone. |
[Share here] Dynamic Camera Configuration / CAMERA ON STANDBY PATCH | bluffmaster | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 630 | 09-04-2012 08:12 |
Nokia 7250: Camera operation failed! Camera on standby | Syri | Nokia Hardware & Hardware Repair | 11 | 06-01-2011 19:09 |
6270 camera operation failed & camera on standby error | nilesh_patel717 | Nokia Hardware & Hardware Repair | 1 | 01-08-2010 06:32 |
5610 camera *CAMERA ON STANDBY* help! | khan6653 | Nokia Hardware & Hardware Repair | 5 | 07-06-2009 14:19 |
camera on standby 6280 says while operating camera | gsmservices | MT-BOX | 0 | 09-06-2006 16:41 |
