11-28-2003, 12:19 | #1 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CT SA Age: 52
Member: 12733 Status: Offline Thanks Meter: 26 | 7210 Loud speaker and ringer I have a 7210 taht works perfectly and speaker works gook but the loud speaker is fazy and the ringer also just noisy like a broken speaker. Put in new speaker but no change. Please help me out here . [email protected] Cheers |
11-30-2003, 11:26 | #4 (permalink) |
Member: 12733 Status: Offline Thanks Meter: 26 | Sorry Changing the speaker is just to take it out and put the new one , I don't see anything to clean here . I though the vibration was from the fromt board but was not the case, I tried to isolate the speaker to the front board but atill the same . Cheers |
12-02-2003, 19:31 | #7 (permalink) |
Junior Member Join Date: May 2003 Location: south africa Age: 42
Member: 30227 Status: Offline Thanks Meter: 0 | hi there check the uem and upp, possible that its faulty or there's dry joint try to maybe give light rework if its not glued! Good luck PS:will find out more at work, but give it ago! |
12-03-2003, 13:27 | #9 (permalink) |
Member: 12733 Status: Offline Thanks Meter: 26 | I got it now , the speaker is not the as loud speaker and ringer ; The loud speaker is on the back cassing under the arial but I have one problem now : How to open without any damage on the cassing, it look like if it is glued. Please if any suggestion , help. Cheers |
12-03-2003, 15:50 | #10 (permalink) | |
Insane Poster Join Date: Sep 2003 Age: 50
Member: 38882 Status: Offline Thanks Meter: 2 | Quote:
NOT POSSIBLE its a sealed unit you need to replace the chassis | |
12-03-2003, 16:20 | #11 (permalink) |
Junior Member Join Date: Mar 2003 Location: Belgium Age: 49
Member: 25274 Status: Offline Thanks Meter: 0 | i had one with same problem, i replaced the buzzer by cutting the frame open inside, and put back a other one and glue it back again ;-) takes some time, but is ok if you don't find the frame ;-) if you cut in the inside side of the frame , nobody will see this from outside the phone... |
12-03-2003, 16:27 | #12 (permalink) |
Member: 12733 Status: Offline Thanks Meter: 26 | Thanks to all @stoffel69 Can you tell me how does this speaker look like ? can it be replaced with anythink else if I can' find the original one ? Cheers |
12-03-2003, 17:37 | #13 (permalink) | |
12-05-2003, 15:17 | #15 (permalink) | |
Freak Poster Join Date: Jan 2003 Location: SL 550 Age: 48
Member: 20490 Status: Offline Thanks Meter: 3 | That was my point Quote:
K300 speaker and ringer | celluniversal | Sony Ericsson Hardware Repair | 14 | 06-11-2010 15:39 |
samsung d500 speaker and ringer not working | barthosyn | Samsung Hardware Repair | 3 | 07-21-2008 22:46 |
M-55 speaker and ringer way needed | jimm07ct | Siemens Hardware Repair Area | 3 | 02-21-2008 19:08 |
z 600 speaker and ringer problems | MAHEBOURG | Sony Ericsson | 0 | 04-02-2007 08:41 |
Increasing speaker and ringer volume??? | Abe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 03-04-2002 09:29 |
