7210c sir i have a nokia 7210c it is battery running olnly half an hour pls help me what should i do regards shammysaini |
pls help me its urgent |
Mobile is short.. i think |
change betty ic only u get good result |
1---------change battery 2---------cgange charger |
sir i have also changed the orginal battery & charger and 2nd thing my mobile is not short |
sir pls help me my nokia 7210c battery is running only half an hour ........ and mobile is not short ................. and not water damage ............ |
short ur centre(battery terminal) pin direct to ground and check |
remove v2000 ----------------------- |
change battery ic your problem will be solved |
the fault in batteryy ic change it or may be its liquid damege the board and clean it with ctc and rehot normaly Br Asghar Hussain movilsat centro tecnologico MovilSat |
where is battery ic pls show me ............... |
where is the battery ic mate's ?? I can't find in schematics..................... to shammysaini remove bluetooth ic & check , many times tested by me post result |
1 Attachment(s) |
i think scsacar is right good work ........... |
