Old 11-24-2012, 07:50   #1 (permalink)
262068's Avatar
Member: 689645
Thanks Meter: 14
7230 problem
have a 7230 its taking usb conectiong and flashin ok but not come in local and not take complet flashing and set not power on and with fbus cable not coneted to pc for flashing
hear is bus chack log with mx key using usb
Connection status: EHCI:HUB:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x]
CMT EM0 ID: 00001040
CMT EM1 ID: 00001030
CMT PUBLIC ID: 25F0000BE1305940593F627CB0B6D743231874BA
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D
CMT ROM ID: 67E82268F29CEA60
Loading CMT secondary boot code
SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3AC0
Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0x91BD2
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 69B93C9
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS HASH: 4431C834027BBA0D18A5ED745CAFA04BA679A74A
Selected firmware certificate matched.
Original Imei: 357407
Original Product code: 0590397
Bluetooth ID: D4C1FC99F2B8
SIMLOCK PA identifier:
[0] PA_SIMLOC30
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Waiting for device boot up ...
Phone not found, retrying ...
Warning: Phone did not reboot to normal mode.
and her is log with fbus cable
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385
ERROR: Packet Error(0xAA), code 0xC0000002
Error details:
Bad contact, TX line remains low !
VCC_PH BSI TX RX RX2 CLK
1 0 0 1 1 0
ERROR: bootstrap failed!
any idea about that
Old 11-24-2012, 08:23   #2 (permalink)
Sagitarious's Avatar
Member: 615730
Thanks Meter: 256
Brother look like its hardware fault, so please reheat the GAZOO & RAPUYAMA ..
The Following User Says Thank You to Sagitarious For This Useful Post:
Page generated in 0.11402 seconds with 8 queries
