7250 keypad problem I have a 7250 with bad keyboard,but it isnt contact failure! I peflow it with hot air.i cleaned the pads,I flashed it with Griffin, but nothing helps!!!! Pls help me!!!! :confused: |
What happened to your phone? Did you drop in water ? What is the problum with your keypad, none of them is working or something else? Could you give some more information? |
the phone had network problem. I changed the PA,network is ok,but nothing works on keyboard after that. |
so the whole keypad itself does not work? you've got the keyboard connector, they are very fine contacts, and always bend. but you said all keypads not working? try changing the filter?... |
7210 Keypad Take Off Pa And See If Still Not Working Pa Ok Check Tracks From Connector To Ground If Ok Reflow Uem :) |
