07-20-2004, 06:44 | #1 (permalink) |
No Life Poster Join Date: Oct 2003 Location: MUMBAI Age: 53
Member: 41672 Status: Offline Thanks Meter: 195 | new 3310 no network found change pf, ant. sw, ccont, cobba, hager, crystal but still showing no network found whats a problem? pls. help me. thanks Last edited by TechPhone; 07-20-2004 at 07:05. |
07-20-2004, 08:41 | #2 (permalink) |
No Life Poster Join Date: May 2004 Location: gsm-land Age: 45
Member: 67419 Status: Offline Thanks Meter: 237 | you have change all ic of the motherboard !!! but if your 3310 is new and no network you have to flash it or to change flash ic becouse its the last responsabile of network now after you have change all.but better is that you will test it becouse some phones not are so easy to repair and will test all components one by one . |
07-20-2004, 09:30 | #3 (permalink) |
No Life Poster Join Date: May 2004 Location: Bandung-Flasher.com
Member: 65947 Status: Offline Thanks Meter: 135 | some new 3310 have a bad board. some line broken inside pcb. I have 2 3310 has change all ic but still no network. It's just for information, if I 'm wrong please correct me. BR |
07-23-2004, 20:17 | #4 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Bandung - West Java, Indonesia Age: 43
Member: 71273 Status: Offline Thanks Meter: 14 | i agree with Delta GSM, i have 5 case in the same phone but still no result, it's just information too does any body have a suggestion ???? Best Regards |
07-24-2004, 05:05 | #5 (permalink) | |
Junior Member Join Date: Jul 2004 Age: 44
Member: 71626 Status: Offline Thanks Meter: 0 | Quote:
3310 no network,no signal | xyzjojo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 14 | 11-14-2013 04:27 |
nokia 7360 says no access/no network found | peraltech | Nokia Hardware & Hardware Repair | 8 | 08-16-2009 15:56 |
3310 DAED AND 3310 NO NETWORK | ezz2003 | Nokia Hardware & Hardware Repair | 9 | 06-16-2007 18:03 |
3310 v445 g No Network Found [Manual] I Need Help | gsnbhagawan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 01-18-2002 07:01 |
No network found after unlocking | sdimitri | x1x to x45/x50 | 10 | 08-06-2001 17:26 |
