Old 10-26-2007, 08:04   #1 (permalink)
Member: 526708
Thanks Meter: 81
Thumbs down 7610 Phone Start-up Faild & All Time Restart Pls Help Me
I Try Alredy Full Flash And Erash Flash, Flash Ok But I Try User Area Format But Not Formeting User Area And I Try Ui Settings, Ui Settings Faild. I Try Manualy Format And Format 50% Complite Then Phone Restart And Show Phone Start-up Faild And All Time Restart This Phone. Pls Help Me
Old 10-26-2007, 08:54   #2 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
brthr check this.....
Old 10-26-2007, 09:05   #3 (permalink)
Registered User
Member: 572549
Thanks Meter: 175
reheat flash ic sir.. and flash again with latest version
Old 10-26-2007, 09:34   #4 (permalink)
Member: 613299
Thanks Meter: 6
try to reheat only on upp, i think it will be ok
Old 10-26-2007, 09:49   #5 (permalink)
Member: 526708
Thanks Meter: 81
thnx ur reply,i try this solution but same problem, any other solution???????
Old 10-26-2007, 09:54   #6 (permalink)
Member: 526708
Thanks Meter: 81
thnx ur repply, i alredy rehot flash ic same problem
Old 10-26-2007, 10:08   #7 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 639
not flash ic mate only sram if no luck replace ram everthing will be ok
br
Old 11-19-2007, 04:16   #8 (permalink)
Member: 176892
Thanks Meter: 37
br
This realy rigth Method for repair with Reboot 7610 from SRAM is broken (Full Flash ok, Phone can Power On but it restart).
Don't post only peharp in hardware section coz It will problem with all user trying to follow you if not clear please don't making posting it in here.
Br,
The Following User Says Thank You to gsmcambodia For This Useful Post:
Old 11-19-2007, 04:24   #9 (permalink)
Member: 524530
Thanks Meter: 4
try to reball and reheat nor flash once,goood luck.
The Following User Says Thank You to pa_trix For This Useful Post:
Old 11-19-2007, 07:14   #10 (permalink)
Member: 217853
Thanks Meter: 13
do what digitized is posted problem will get solved 100% dont rehot flash, ram or cpu becoz it has nothing to do with urs problem.
The Following User Says Thank You to rajus For This Useful Post:
nokia 7610 phone start-up faild sheikhmax WD2 & APE (Symbian Phones) 8 04-26-2010 04:21
7610 Phone Start-up Faild.contact The Retailer harisha g h Nokia Hardware & Hardware Repair 9 03-08-2010 20:37
nokia 7610 phone start-up failed help me pls palav Nokia Hardware & Hardware Repair 15 12-11-2009 07:58
7610 Phone start-up failed & User Area Format Failed agianmaker WD2 & APE (Symbian Phones) 18 09-15-2009 21:04
Page generated in 0.19734 seconds with 10 queries
