10-08-2005, 21:00 | #1 (permalink) |
No Life Poster Join Date: Jun 2003 Age: 37
Member: 30303 Status: Offline Sonork: 1001579198 Thanks Meter: 17 | 7610 2nd Bood Error Urgent Help when i try to flash it say 1st Boot Ok, WD2, UPP: 1081 2nd Boot Error: 6 Platform: 6, Error Data: E3 72 72 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 pls help me guys ....................i am waitin for help i tryd to cleen reheated all board but still sam pls help me |
10-09-2005, 09:00 | #2 (permalink) |
Freak Poster Join Date: Jul 2005 Location: cebu Age: 43
Member: 164237 Status: Offline Thanks Meter: 12 | you have to change the flash ic's... i tried to replace it with UEM same problem but did not worked.. tried also with other flash file or erase flash but did not solve the problem... my solution would be change the flash ic's |
10-09-2005, 11:03 | #4 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: Aunlock Age: 43
Member: 80354 Status: Offline Sonork: 100.1577575 Thanks Meter: 21,659 | Quote:
2nd trying Erase flash Via Griffin 3rd Trying Flash Without Bluetoth flashing i hope solve problem J@wad | |
10-09-2005, 11:03 | #5 (permalink) |
Insane Poster Join Date: Aug 2005 Location: bangalore -india Age: 45
Member: 167560 Status: Offline Thanks Meter: 1 | [QUOTE]7610 2nd Bood Error Urgent Help -------------------------------------------------------------------------------- i got set when i try to flash it say 1st Boot Ok, WD2, UPP: 1081 2nd Boot Error: 6 Platform: 6, Error Data: E3 72 72 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 replace flash ic even then same problem means replace even uem will surely work kssinfo www.kssinfotech.com |
10-09-2005, 14:44 | #6 (permalink) |
Junior Member Join Date: Jul 2005 Age: 42
Member: 160349 Status: Offline Thanks Meter: 1 | upp(4377007) always make a problem in 7610 phone...take it out and rework it back using the normal solder cream..DON USE LEAD FREE SOLDER CREAM..couse lead free upp always make a big problem in 7610 phone..if u wanted replace the upp batter u replace (4377001) upp.it is not lead free |
10-10-2005, 08:30 | #8 (permalink) | |||
No Life Poster Join Date: May 2001 Location: Manila, Philippines Age: 53
Member: 4408 Status: Offline Thanks Meter: 5 | Quote:
after following suggested procedures below you need some other steps if you changed your flash IC's, its either make ask files to retain your original IMEI or CHANGE UEM and write new rpl. Quote:
10-11-2005, 21:09 | #11 (permalink) | |
Junior Member Join Date: Jan 2005 Location: Moskov Age: 44
Member: 111481 Status: Offline Thanks Meter: 0 | Quote:
1st Boot - loading primary bootloader in internalRAM MCU, reading ID MCU and platforms 2st Boot - loading of the basic bootloader in externalRAM. I correctly understand process? As I understand, 1st Boot and 2st Boot should not depend on serviceability at all and in general presence FLASH, therefore that met devices at which from for mechanically damages FLASH or it was not read in general, or incorrectly gave out the ID, that could occur at damaged channels of the data and therefore disabled. | |
7610 white LCD Please Urgent Help need | abdurrahimsagar | Nokia Hardware & Hardware Repair | 12 | 03-16-2010 07:09 |
N91 2nd boot error please help | MR.MAMUN | Nokia Base Band 5 ( BB-5 ) | 0 | 02-23-2010 08:13 |
7610 camra system error.pls help me??????????????????????/ | excellantraja | Nokia Hardware & Hardware Repair | 2 | 12-13-2007 05:34 |
Nokia 7610 2nd Boot Error | rajus | Nokia Hardware & Hardware Repair | 8 | 04-09-2007 20:22 |
6600 2nd boot error plz help | .::ricky rayya::. | Nokia Hardware & Hardware Repair | 8 | 10-09-2006 16:02 |
