01-20-2007, 14:00 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | 7610 After Flash NoT Power On ============= Set Flash mode for info ============= VBat is 3.94V Vpp pin has 0.09V, Not Connected Pins: Mbus 0, Box Tx 1, Box Rx 0, Bsi 0 Boot... WD2 BT2 w3_2nd.fia w3_amd.fia ASIC ID: 1081 Configuration Info (9F): Number of Flashes: 4 00000000: Samsung, 00EC 22F8 0000 0011, 10 02000000: Samsung, 00EC 22F8 0000 0011, 10 04000000: Samsung, 00EC 22FA 0000 0011, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA UEM IMEI is: 3557000090**** ============= Set FBus mode for info ============= VBat is 3.92V Vpp pin has 0.10V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Processing File: RH51_52_67_68PE605220.C1 Boot... ASIC ID: 1081 WD2 BT2 w3_2nd.fia w3_amd.fia 841E89FF79CC1FDEBC42526FE0F4 Configuration Info (9F): Number of Flashes: 4 00000000: Samsung, 00EC 22F8 0000 0011, 10 02000000: Samsung, 00EC 22F8 0000 0011, 10 04000000: Samsung, 00EC 22FA 0000 0011, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Erase[24.69 MB]... erasing region [00000000 to 0000FFFF] erasing region [00010000 to 00FFFFFF] erasing region [02000000 to 0287FFFF] erasing region [02FC0000 to 02FEFFFF] in 190.69s Flash[24.51 MB]...in 104.52s * * Processed file in 311.42 seconds Processing File: RH51PE605220.03 Boot... ASIC ID: 1081 WD2 BT2 w3_2nd.fia w3_amd.fia 84A79F0B30A4463F5A0C13A96F40 Configuration Info (9F): Number of Flashes: 4 00000000: Samsung, 00EC 22F8 0000 0011, 10 02000000: Samsung, 00EC 22F8 0000 0011, 10 04000000: Samsung, 00EC 22FA 0000 0011, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Erase[2.75 MB]... erasing region [00000000 to 0000FFFF] erasing region [02A00000 to 02CAFFFF] in 23.19s Flash[2.73 MB]...in 16.58s * * Processed file in 56.30 seconds * * * Phone flashing done in 6:10 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! |
8330 after flash not power on | scoicagsm | LG | 0 | 10-05-2006 12:50 |
W810i after flashing not powering on | Nasmi | SonyEricsson (USB-Smart) | 4 | 08-08-2006 08:12 |
W810i after flashing not powering on | Nasmi | Cruiser Suite | 1 | 08-03-2006 03:47 |
7610 after flash not switch on | apple inside | Nokia Hardware & Hardware Repair | 1 | 04-06-2006 12:55 |
t100 not power on after flash, not power on when original cable is plug | GYZMO | VLSI, Conexant, Skyworks and Old Models | 8 | 01-07-2004 00:34 |
