7610 big problem i have a 7610 showing nokia ......i software on ufsx ....mt is not flashing ....i reball power ice, cpu, flash , ram ,but still same what i do |
Erase all flash. Flash again with write pm. Lucky. If not work reject LCD and reflashing. |
boot ic faulty change it |
so i tried too many times with mt but no sucess.. so i flash it with ub with latest version but before flash i full erase flash with ub i flash it with these files mcu RH51_52_67_68PE706420.C1 ppm RH51PE706420.01 and my problem solve if you have ub then you can try it with ub best of luck |
Quote: Originally Posted by unlock_solution i have a 7610 showing nokia ......i software on ufsx ....mt is not flashing ....i reball power ice, cpu, flash , ram ,but still same what i do I guess you have to change to Jaf box compare to other box because its much stronger than mt or ufs box. and you will think that its a hardware problem when you use other box coz it cant make your phone work again. i tried this many times on 7610 models. |
just change the boot ic and format the phone |
