7610 LOG ( missed calls,...) and contacts problem with startup failed hi dears, when i enter in the contacts menu of nokia 7610 it say that "Database Corrupted.Some data might have been lost." and after that show this too "Contacts : Already in use" i cannot save my all sim directory numbers to contacts too. often 20 number from 100 can be save. in the main menu LOG icon is not working (dont open). phone sometimes go to startup failed contact retailor. what can i do for solve this problem? i flash it with ufs3 many times and write pm file too but nothing changed:confused: thankyou |
format user area with magic kays (*,YES,3,POWER ON) |
i did it before but problem remain also:confused: |
i think that it has a hardware problem any idea? |
its 100% software problem remove the MMC and flash a new firmware+format user area it will be solved 100% do not use any app on your phone if you think its a HW problem in your flash memory you can erase them one by one with UFS3 and check if anyone is broken BR IR-GSM |
IR-GSM is right removed MMC and format user area,FFactory set LM,set factory default and unlock it...note use griffin it is the best box that i had use for formatting...hope you'll made it... |
thx galo for completing my task you are right griffin is a legendry box that nobody could forget BR IR-GSM |
thankyou dear IR-GSM i flash it by ufs3 its ok.after that when i power on the phone all things is normal ( all applications, log-profile-setting-contacts-...) too ,but when i want to enter contacts menu and want to copy new sim to contacts as the normal condition of nokia 60 series the problem begin and it say ... ( first thread problems). i have no griffin box and i dont know how can i erase flash memory one bye one with ufs3 if some broken. anyway thankyou i ll do it and say result here many many thanks regards Persia-Gsm |
stop trying software,tat might be ram prob,change the ram might help...i am not 100% sure but i've the same prob in 6600,after change the ram,it fixed... |
if problem stil remain ,then try to change the flash ic ..k8 6415 |
thankyou very much |
no need for griffin you can do it with ufs3 for sure first I still think it is software problem, do you use the latest version for 7610? please check it out and try the latest 6.0522 or later if come out second use erase button of ufs3 3time: first time let it erase standard add second time change beginning add to 0200000 third time change the start add to 040... and end add to 0470... then if you have no erase eror, be sure your flash ics are ok and reflash it with latest version and do not forget pm and format user area third in 0.01% maybe steven hong is right (but I don't think so) so you must reheat SRAM IC if the two ways above failed in action if I was you I test the second schedule BR IR-GSM |
dear IR-GSM many thanks for your solution that i think its fantastic my friend. it was best answer which i heard about my problem up to now. perfect i thank all specialy from you and steven hong.you are my best friend here. i ll check it and tell you about result. BR persia-gsm |
