7610 ...... Contect Retailer i have 7610 its show me contect retailer................. what i can do i try to by software..... 1--MCU Sw: V 7.0642.0 18-10-06 RH-51 (c)NMP PPM Sw: V 7.0642.0 18-10-06 RH-51 (c)NMP.03 BT Det: Prd.Cd: 0514521 Bpr.Cd: 0511637 Pro.Sn: DDE722549 HW : 6003 UEM : 144 UPP : 4225 RFIC : DSP : IMEI : 352273-01-718899-3 SLconf: 001-01-00000000000 SLprof: 000000000000000-5 SLvar : 00553522730171889900 SLaux : 00055555 HwSig : 7FC308FC77A2C53D BoxId : 894F61AF4016A3EB MastCode: 60 40 10 36 61 Provider: GSM Test Equipment #pw+ 338 146 554 623 450 +1# #pw+ 405 237 527 364 044 +2# #pw+ 484 017 102 232 025 +3# #pw+ 824 191 346 243 103 +4# #pw+ 259 355 775 735 061 +5# #pw+ 423 327 745 145 631 +6# #pw+ 082 913 104 041 426 +7# 2----UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007. S/n: 83470 HID: 3C1EC14A0027000F HWK: A1.04-PRO1 Features: 00000001 Licence : True User Area Format Failed 00000000: 00 24 00 C0 05 04 01 C2 .$...... what i can do now.................... |
flash it with jaf, then write pm , and show me the result |
first check it manualy formate , if ok then after formate with box.... or erase with 6600_fullerase_file > full flash >pm>unlock>facset>formate. post result here BR Amit Tank |
Full Erase with Friffin B0xII Then re-flash,Write PM.Should be OK.If still change Flash ram.( the small flash one) |
reball the flash ic post result |
first flash with latest version and write pm then formate with ufs. post me result. |
with ufs, Write pm file, and then ui setting one step by one step. if this solution can't do, change or reball flash ic 64mb |
format phone this format * 3 call button and on\off switch continues press this problem 100% solved |
i done every think by software is hardware problem ....??????? any mate explain me ... why nokia wd2 ... show the contect retailer....???????????? i done formet by usf , ub ,,mt,, i erase flash ,,@ write latest file .. write pm @ unlock..... any mate explain why r we facing this @ how to solve..??????????? sanjuwatch............... |
1 Attachment(s) Quote:
Try this solution then post result |
Just resold flashes and upp uem |
just rebool f12 and formet user aera 4time...... 100% working reply.. |
just rebool f12 flash ic and formet user aera (ufs) 4time...... 100% working reply.. |
