Old 06-28-2005, 18:36   #1 (permalink)
Member: 150552
nokia 3310 fall into water
I have a nokia 3310 that fell into water and i flash the phone with twister after cleaning but did not power on. i am havig the feeling that the problem is CCONT but i dont know how to shange it with my SMD rework station.pls help with solution and method
Old 06-28-2005, 18:43   #2 (permalink)
kardelen gsm's Avatar
Member: 133173
Thanks Meter: 119
Hi
flash is ok ..??????????
Old 06-30-2005, 13:06   #3 (permalink)
Member: 150552
thanks man, flash is ok with twister but when i try to reboot in normal mode or set to factory setting , it shows bad mob arck, process failed
Old 06-30-2005, 13:43   #4 (permalink)
Member: 133173
Thanks Meter: 119
use knock or geoflasher...try to flash the phone..not result.. check attachment.and not result...flash ıc damaged change flash ıc...regards
Old 07-07-2005, 03:57   #5 (permalink)
Crazy Poster
Member: 144686
With that wire are you soldering it to all those holes that is passing?
nokia n90 fall in sea water tarey888 Nokia Base Band 5 ( BB-5 ) 0 01-06-2007 17:54
n70 dead after fall into waterr achinxz Nokia Hardware & Hardware Repair 0 12-29-2006 05:45
3310 fell into water ovie sanco Nokia Hardware & Hardware Repair 0 06-29-2005 13:18
Nokia 3310 droped in water viaop Nokia Hardware & Hardware Repair 0 08-07-2002 11:10
how to repair no signal after phone falling in water brittnee Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 05-11-2001 19:33
Page generated in 0.19590 seconds with 10 queries
