06-19-2008, 00:55 | #7 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 339455 Status: Offline Sonork: 100.1589401 Thanks Meter: 86 | hello erase phone full flash with good firmware write good pm unlock full factory defaults if problem has been software problem it must be solve. try it and post its result. |
06-19-2008, 06:08 | #9 (permalink) |
Freak Poster Join Date: Apr 2008 Location: trivandrum
Member: 753208 Status: Offline Sonork: adams Thanks Meter: 62 | try to rrehot flash ic or reboll it. then full flash with pm it will be ok |
The Following User Says Thank You to adamsmobiles For This Useful Post: |
06-19-2008, 10:23 | #13 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Back after long time :-) Age: 40
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Try to format the phone manually *,3,green button,on off switch & unlock the phone by any tool.Your problem is solved. Thankz. Xtreme Mobile. BRB. |
06-19-2008, 11:43 | #14 (permalink) |
No Life Poster Join Date: Oct 2006 Location: U A E
Member: 364745 Status: Offline Thanks Meter: 719 | br if u have all try with software not solved your problem so open the set and rebal upp and then again try flsh i hope your problem solved lats time i have repair this problem ............ Best Regard Br IKRAM BUTT |
7610 Phone Startup failed contact the retailer | Misbahullah | HWK | 10 | 09-13-2009 20:21 |
7610 Phone Startup failed Contact to Retailer | Kethey | WD2 & APE (Symbian Phones) | 28 | 08-05-2009 08:32 |
7610 phone startup failed contact the retailer | .::ADNAN440::. | Nokia Hardware & Hardware Repair | 5 | 08-03-2009 16:35 |
6070 phone startp falied contact retaler | sushilkumar | Nokia Hardware & Hardware Repair | 6 | 06-19-2008 00:21 |
