04-16-2005, 13:26 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: NEW DELHI, INDIA Age: 50
Member: 111665 Status: Offline Sonork: 104250 Thanks Meter: 180 | 7610 start up fail |
04-16-2005, 13:49 | #2 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: www.sevgigsm.net Erkan Yasar Age: 61
Member: 81576 Status: Offline Thanks Meter: 2,128 | Quote:
1-griffin format user aria test 2-6670 softvare horse | |
04-16-2005, 14:27 | #4 (permalink) |
Member: 111665 Status: Offline Sonork: 104250 Thanks Meter: 180 | I have done it with Griffin platinum but no use, it dose not switches on after flashing done in griffin, no local mode in Griffin but in ufs-3 it works fine, Format user area done and flashing done, In griffin when it comes AFP after flash process it dose not turns in local mode, |
09-04-2006, 10:36 | #12 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Inside PM
Member: 258154 Status: Offline Thanks Meter: 319 | Hi Mate Following Steps can Help u 1) try *+3+ green + power buton Check if formatting completes or not if yes the slightly Heat the Flash IC's and then Erase and Full Flash phone with latest flash files..if not 2)Flash IC in your phone is faulty..Try to replace it Try and Reply Regards Adampur Hawks |
7610 start up failed | ikram tabassum1 | Nokia Hardware & Hardware Repair | 9 | 10-08-2008 10:59 |
7610 start-up failed | ikram tabassum1 | Nokia Hardware & Hardware Repair | 5 | 09-23-2008 17:36 |
Nokia 7610 Start Up Failed Contact Retailer Solution | RAJAN62073 | Universalbox | 3 | 07-17-2008 19:24 |
7610 start-up failed affter 30min pwoer off | ashrafcell | Nokia Hardware & Hardware Repair | 6 | 06-11-2006 09:50 |
7610 start-up fail | kenichi | Twisterflasher | 7 | 07-16-2005 15:19 |
