12-06-2008, 17:01 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Tunisia my love Age: 43
Member: 304362 Status: Offline Thanks Meter: 347 | 7610 start up failed contact retiler MCU ID: 0x1081 Reading flash chip detailes... FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA MCU ID: 0x1081 Boot is ready... Algo is ready... Loader is ready... Erasing area: 00000000 - 00FFFFFF... Done! Erasing area: 02000000 - 02FFFFFF... Done! Erasing area: 04000000 - 04FFFFFF... Done! Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE605220.C1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE605220.20 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Croatian,Slovenian (Croatia & Slovenia) MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE605220.C1 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x10D8 Boot is ready... FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0xDDFE00EC Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7F10; Loader chk: 4 Loader is ready... P-key nokia module version 01.02 MSID: 84AB9220425C27AA31D509226E MSID decoded: 3E4EBAEF000938F2A9000018 FAID: 5CF15AF776724D4EBEC0FF00 Operation took 0 minutes 25 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 00FFFFFF... Erasing area: 02000000 - 0287FFFF... Erasing area: 02FC0000 - 02FEFFFF... Operation took 2 minutes 40 seconds... Writing... Perm. Data Restore OK Operation took 3 minutes 5 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE605220.20 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x10D8 Boot is ready... FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0xDDFE00EC Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7F10; Loader chk: 4 Loader is ready... P-key nokia module version 01.02 MSID: 84F812DEA61CAB7939EF5E5F74 MSID decoded: 3E4EBAF9000938F2AA000006 FAID: 77DEC1E5337A75836D0AD5B9 Operation took 0 minutes 19 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 02A00000 - 02C8FFFF... Operation took 0 minutes 17 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 20 seconds... Restarting MCU... Flashing Done! Operation took 7 minutes 11 seconds... After flash processing... Waiting for phone to boot... Product code changed to 0514468 Reading... Failed! Aborting!...MCUVER kan anu one help me |
12-06-2008, 17:11 | #2 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | hello use ufs 1........erase all addresses manually (use erasing guide exe) 2....... flash with these files (RH51_52_67_68PE706420.C1) and (RH51PE706420.03) 3..............after flash write pm file 4.............do ui setting 5.............at last press format user area (if need press 2nd/3rd times whenever the error "phone start up fail contact the retailer"not clear Last edited by zeerik; 12-06-2008 at 17:19. Reason: XXXX |
12-09-2008, 02:54 | #8 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | Quote:
after flash write pm format then uclock for that reading your phone is dead or white screen... | |
7610 Phone start-up Failed. Contact the Retailer??? | byteforce | Griffin | 22 | 10-04-2011 15:26 |
Nokia 7610 Start Up Failed Contact Retailer Solution | RAJAN62073 | Universalbox | 3 | 07-17-2008 19:24 |
7610 Phone Start Up Fail Contact Retailer | PARMATMA | Nokia Hardware & Hardware Repair | 16 | 07-14-2006 20:01 |
7610 phone start up failed.contact the retailer | dogandbone | UFS2 + UFS3-Tornadoflasher | 5 | 11-15-2004 21:13 |
