11-10-2009, 00:54 | #1 (permalink) |
Junior Member Join Date: May 2007
Member: 512359 Status: Offline Thanks Meter: 4 | 7610 water damaged it worked after cleaning but stoped on nokia I tried formating from the Jaf the same pro then I tried factory setting but failed and the phone give "" contact retailer"" I tried manual flash but it isn't working I tried to flash it all the flash is OK but in the last give ""failed factory setting"" and still the same pro check is OK and this is the info after flashing Getting MCU ID MCU ID: 0x1081 FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... Master Code: 7753730235 Failed! Aborting! MCUVER any body can help me?? |
11-10-2009, 04:38 | #2 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: ONLY PRIVATE MSG
Member: 220932 Status: Offline Sonork: 100.1592154 Thanks Meter: 110 | Quote:
bro first check boot ic | |
The Following User Says Thank You to soy For This Useful Post: |
11-10-2009, 13:07 | #3 (permalink) |
Member: 512359 Status: Offline Thanks Meter: 4 | thanks very much for your reply this is the info again Getting MCU ID MCU ID: 0x1081 FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... Master Code: 7753730235 Failed! Aborting! MCUVER FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... Master Code: 7753730235 Phone type: RH-51, Software version: 7.0642.0, Language Pack: not available User code: 12345 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-51.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0514536 Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-51\ Searching for default location of ini... Checking path: \Products\RH-51\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-51\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Done! |
7610 water damage | kasra_tcme | Nokia Hardware & Hardware Repair | 7 | 09-01-2008 09:48 |
Nokia 6230 water damaged No Reception after ultrasonic cleaner | MC Harami | Nokia Hardware & Hardware Repair | 1 | 02-04-2008 05:24 |
Nokia 6010 *Water Damage* Still works. | iviyst | Sell ur Old and Used Stuff | 0 | 02-05-2007 17:57 |
7610 water damage taking flash not getting on | monti_908 | Nokia Hardware & Hardware Repair | 4 | 03-02-2006 11:22 |
Nokia 7610 water damage | cellunlock.com | Nokia Hardware & Hardware Repair | 2 | 04-19-2005 16:32 |
