Old 01-18-2006, 09:17   #1 (permalink)
Member: 222180
7650 help PA solution
help!!!! is there any solution to 7650 without using P.A.? jumper solution could it be work?
tnx.....
Old 01-18-2006, 14:14   #2 (permalink)
Mang mel's Avatar
Member: 218941
Thanks Meter: 1,801
no my friend....if yo used jumper the voltage is weak..
the result is weak signal...its no network if far from site..my eperience..find new power amplifier..
Old 01-19-2006, 01:51   #3 (permalink)
Member: 222180
tnx mmb06......do u have any idea or diagram to make jumper with that?
Old 01-19-2006, 12:31   #4 (permalink)
naughtycell's Avatar
Member: 214350
Thanks Meter: 17
I will give you my expert , I was working very near to the GSM tower ( near 25 meter ) and to be sure of my thoughts about Tx or power off , I was bridging the Power amplefire's (900Mhz) input to output , ofcorse after raising of the chip ( there is no PA there ) , then phone works normally .
that was for testing because PA is the Tx amplefire without it work will be nonconvinient !
Old 01-20-2006, 07:17   #5 (permalink)
Member: 222180
tnx naughtycell..... could u please give me a diagram how to bridge the power amplifier for 7650?
Old 01-21-2006, 07:59   #6 (permalink)
Member: 214350
Thanks Meter: 17
Bridge pins of the PA 4 to 21 / and 5 to 14 . without the presense of PA chip .
I'm not sure from results of 1800Mhz bandwidth.
bb 8100 pearl PA solution (need help) malcomx14 BlackBerry (RIM) 0 08-07-2009 05:46
K300 K500 Pa Solution With T190 Work 100% bocahklaten Sony Ericsson Hardware Repair 4 11-03-2008 12:00
7650 4x blink solution needed douda WD2 & APE (Symbian Phones) 14 08-23-2004 07:11
7650 showing "NOKIA" Solution!! datalife2000 WD2 & APE (Symbian Phones) 22 07-14-2003 14:48
7650 problem any solution welly2000 WD2 & APE (Symbian Phones) 2 03-07-2003 15:52
Page generated in 0.17185 seconds with 9 queries
