Old 12-28-2007, 03:15   #1 (permalink)
Member: 156293
Thanks Meter: 14
Help 7610 Restart ....
7610 storing and restart when make call,if use HF to make called,its no problem,anyone can help me????
Old 12-28-2007, 21:43   #2 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
Hi ,at First U Check With New Bettary If Not Done Then Format Manuly * 3 Yes And On/of Switch Pause Set Take Auto Format I Think Set Will Be Ok If Not Done Then Wash And Keep Bulb Hit 20 Munite I Think Problem Will Be Ok .............good Luck
Old 12-29-2007, 01:43   #3 (permalink)
Member: 156293
Thanks Meter: 14
just format,reflash,replace audio ic,rf ic,cpu but still same,another solution??
Old 12-29-2007, 04:13   #4 (permalink)
WinD_VteC's Avatar
Member: 647414
Thanks Meter: 127
hello frenz... u try to reball the power ic or ram ic if cannot u change it... the ic
WinD
Old 12-29-2007, 17:03   #5 (permalink)
manyosa's Avatar
Member: 271974
Thanks Meter: 97
Try to format it and post the results.
7610 restart ziko WD2 & APE (Symbian Phones) 16 06-02-2006 06:12
nokia 7610 restart helin WD2 & APE (Symbian Phones) 2 01-31-2006 09:42
7610 restarts and no gallery darkblues Nokia Hardware & Hardware Repair 2 10-05-2005 13:07
7610 Restart Problem SATISH WD2 & APE (Symbian Phones) 2 04-19-2005 07:35
7610 restart if insert simcard bengkel_hp Nokia Hardware & Hardware Repair 6 04-01-2005 20:32
Page generated in 0.13784 seconds with 9 queries
