10-11-2003, 16:17 | #1 (permalink) |
No Life Poster Join Date: Oct 2002
Member: 17330 Status: Offline Thanks Meter: 15 | 7650 shorting the battery What component(s) can cause this problem? I was able to flash this phone with Griffin, obviously it is still dead. Any help will be appreciated Thanks |
10-13-2003, 19:52 | #5 (permalink) |
No Life Poster Join Date: May 2002 Location: asia Age: 53
Member: 11742 Status: Offline Thanks Meter: 1 | it is indication for short pa . remove the resister just below the pa,it is in series to pa+v from battry and check or remove pa. +volts from battery goes direct to pa. |
10-29-2003, 17:55 | #6 (permalink) | |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | Quote:
10-29-2003, 19:00 | #7 (permalink) |
Member: 11742 Status: Offline Thanks Meter: 1 | @Hanukkah yeh u r 100% wright.it is a rfc [radio frequency chock or coil] it looks like a resister ,so for the pplz not familiar with electronics or less experienced, i wrote it resister. |
11-01-2003, 00:40 | #9 (permalink) |
Member: 5246 Status: Offline Thanks Meter: 9 | @paygee No problem m8, just wanted it straightened out. People should call the parts as they are so as not to confuse our mates here. Some might think you are referring to a "resistor" and not the coil. |
11-01-2003, 10:58 | #10 (permalink) |
Member: 17330 Status: Offline Thanks Meter: 15 | You are right. I was actually looking for a resistor. Now to the real problem Removed the coil, I still had the short. I guess I have to replace the PA. But where can I get a replacement? Who sells them? Thx |
11-01-2003, 12:32 | #12 (permalink) |
Member: 17330 Status: Offline Thanks Meter: 15 | 1- Do you mean I should change the coil? Will this coil cause this problem? 2- Will the big resistor also cause this problem? I will try changing the flat ribbon cable I have changed the keypad board same problem As soon as I replace these, I will post results. Thx |
11-01-2003, 14:20 | #13 (permalink) |
Member: 5246 Status: Offline Thanks Meter: 9 | When you remove the coil and there is still short, this means your PA is not faulty as you have just isolated the PA from the board by removing the coil... You will have to look for the short somewhere else. Try removing the LCD module and check for shorts.. or UEM... or AEM |
K310 Short Battery Life. i changed the battery but no change. | xim360 | Sony Ericsson Hardware Repair | 4 | 12-15-2009 05:19 |
7650 shorted .. | Mang mel | Nokia Hardware & Hardware Repair | 1 | 01-15-2006 17:03 |
7650 Shorted... | Mang mel | Nokia Hardware & Hardware Repair | 1 | 01-15-2006 15:59 |
short time battery live in new v600 | olgierd_jedlina | Motorola P2k | 3 | 03-15-2005 12:41 |
8310 succking the battery {drop the battery } | moobile mafia | Nokia Hardware & Hardware Repair | 4 | 09-14-2004 15:10 |
