12-02-2003, 18:07 | #1 (permalink) |
Crazy Poster Join Date: Apr 2003
Member: 27569 Status: Offline Thanks Meter: 0 | 8210-8250 drain battery very fast!!!! I always have a problem on these 82xx series phones when they are water dameaged. I REMOVE (without All these IC's) PA, CCONT, COBBA, UI, Charging CHAPS, HAGAR and antenna switch. The phone still short circuit when i use the ohm meter to test + and - point at the battery connector there.... there's a leakage and it drains battery very fast.... I clean the pcb with thinner. Can somebody assist me? Thanks In Advance |
12-02-2003, 18:48 | #2 (permalink) |
No Life Poster Join Date: Apr 2001 Location: รำมว&#
Member: 3956 Status: Offline Sonork: galletto3 rules :D Thanks Meter: 55 | hi, drain battery is suspicious simptom, change display and check if everything ok, 80% is display problem best regards Invisible |
12-02-2003, 22:06 | #3 (permalink) | |
Member deceased !! Join Date: May 1999 Location: Wien/Austria Age: 65
Member: 5 Status: Offline Thanks Meter: 1,884 | Re: 8210-8250 drain battery very fast!!!! Quote:
12-02-2003, 22:27 | #4 (permalink) |
Insane Poster Join Date: Oct 2002
Member: 16859 Status: Offline Thanks Meter: 0 | other part may be FLASH ROM... I had same problem with water damaged 8210 After changed FLASHROM works But Flash not easy to remove flash rom Use water flux for removing glue under flash or heat it when you se near solder balls around flash use a surgeon knife or any sharp tool to remove flash It's very difficult... BE CAREFUL |
12-03-2003, 02:42 | #5 (permalink) |
Member: 27569 Status: Offline Thanks Meter: 0 | First of all, sorry for the spamming, i don't know which section to input the problem i encounter. I'm sorry. Thanks for the Info, i will try to change it and see. Thanks!! Will let u know the results these few days. cos now i'm outstation somewhere. |
01-20-2005, 20:24 | #11 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | in a nokia 2100 , i am also having the same problem as the resistance between the +&- is zero...what to do? the set was water damaged...but it is on now.. but the battery discharges very fast and there is no network... and i have also changed the PA..but same problem remains... help/// Last edited by gsmsikar; 01-20-2005 at 21:10. |
LG KG800 (Chocolate) draining battery very fast even when OFF | BONDIE_86 | LG | 0 | 03-11-2010 03:40 |
6630 drains battery very fast | IvailoShopov | Nokia Hardware & Hardware Repair | 10 | 02-08-2007 03:56 |
8210 consuming battery very fastly | Shahrukh | Nokia Hardware & Hardware Repair | 10 | 02-11-2004 16:16 |
