Old 05-03-2002, 07:53   #1 (permalink)
Member: 3627
Thanks Meter: 2
8210 battry full when i call battry low
hi to all
i have 8210 when i put the battry full and after i make a call the battry low ....
please i need your help.....
thanks a lot
tone
Old 05-03-2002, 10:17   #2 (permalink)
hacker1gsm's Avatar
Member: 5113
Thanks Meter: 10
hi
try to change the PA
i do it for 5 phones and it works
regards
Old 05-03-2002, 14:48   #3 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
Thanks Meter: 69
I have too
Hi hacker1gsm:
I had this problem before and changed pa works 100%
but all of my customers says: that in 3-4 minutes of calling sound will be creckling and call will disconnect,
do u know solution?
Old 05-03-2002, 15:24   #4 (permalink)
Member: 3503
Thanks Meter: 2
PA changing is not a correct solution
you just need to change battery[crapy duplicate chinease]
just test it with your test battery [battery from phone with is working well]
just open the battery shield cover in duplicate battery to adjust the weight small rod is inside then it is crapy duplicate chinese battery
post your result
[email protected]
Old 05-03-2002, 16:00   #5 (permalink)
Member: 461
Thanks Meter: 2
Try calibrate power valures with Wintesla
Old 05-03-2002, 19:23   #6 (permalink)
D-Brain's Avatar
Member: 7301
@ARC
If the audio is crackling (distorted) and calls drops, try resoldering COBBA IC !!
All Nokia 3210 and 8210/8850 have a lot of problems on COBBA solder balls!
Old 05-04-2002, 05:12   #7 (permalink)
Member: 2415
@ARC
sure crackling sound most cases caused by
cobba, rehot it and will be fine.
regards,
bone
Old 05-04-2002, 06:46   #8 (permalink)
Member: 10960
Thanks Meter: 5
@ARC
Ok ARC, you changed PA and phone "work" but what is reason his ****n?
- Probably diplexer is bad.
I have few 8210 which in 3 minutes creckling and disconnect call,
also your ear can sense heat at phone.
After change diplexer problem is solved.
Also resold COBBA and CCONT.
Old 05-04-2002, 18:14   #9 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
Thanks Meter: 69
where is diplexer
hi
thanks all
but somebody tell me where is diplexer?
Old 05-05-2002, 04:07   #10 (permalink)
Member: 10960
Thanks Meter: 5
Diplexer is small metal box, right from PA. Like a 26MHz oscilator.
So called "antena switch"
You can use shematic diagram.
Old 05-05-2002, 06:30   #11 (permalink)
Member: 8792
Unhappy
Hi Bello,
Please, send me 8210 shematic and mention where is PA and COBBA.
Thk
Old 05-05-2002, 06:51   #12 (permalink)
Member: 10960
Thanks Meter: 5
This is over 5 Mb.
Go to: http://eh.student.utwente.nl/~landy/...manuals/nokia/
mobile
elibom
Regards.
Old 05-06-2002, 07:29   #13 (permalink)
Member: 8792
Hi Bello,
This link need password.
If you got one, please send me schematic in pdf or gif file at this mail [email protected]
Thank more.
ibrahim
Old 05-06-2002, 09:01   #14 (permalink)
CONTACT-GSM's Avatar
Member: 11571
Thanks Meter: 24
hi ibrahem
landys user: mobile
pass: elibom
Old 05-06-2002, 22:36   #15 (permalink)
nmp
Member: 8004
I had the same problem when I changed leds. and I cant flash it either. What can I do?
6300 whan i calling battry low showdon yahoo.mobiles MXKEY Nokia Flasher and Unlocker (by Alim Hape) 8 03-11-2010 16:29
6120c when I call show low battery Elias Khan Nokia Hardware & Hardware Repair 6 11-18-2009 07:49
8210 showing full reception but calls go to answerphone!! MC Harami Nokia Hardware & Hardware Repair 5 11-10-2004 20:50
8210 turn off when make call askuqi Nokia Hardware & Hardware Repair 2 12-02-2003 15:30
3310 battry full when i call battry low patric Nokia Hardware & Hardware Repair 5 09-23-2002 05:43
Page generated in 0.21239 seconds with 9 queries
