03-27-2002, 06:19 | #1 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Edinburgh UK
Member: 7958 Status: Offline Thanks Meter: 6 | 8210 easy screen repair 6 out of 10 screen faults can be repaired by soldering a small bead of solder..(with a bit of flux ) on the screen connector pads. this pads out the connection to the elastomer and usually sorts out the ........ 'poke the screen and it works faults' regards ps ..jst a small bead...dont go wild. |
03-28-2002, 11:17 | #2 (permalink) |
Insane Poster Join Date: Sep 2001 Location: Philippines
Member: 6460 Status: Offline Thanks Meter: 1 | 90% of no display can be repaired by: 1. cleaning 2. resoldering or replacing the capacitor But how about those unit with okey display but disappear when accessing inbox? How about changing capacitor with a higher value? |
03-28-2002, 12:57 | #3 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Russia Moscow Age: 46
Member: 5889 Status: Offline Thanks Meter: 0 | I changed capasitors with more farad and more and more, I can see message box: write, read, view picture message but If I use picture box more then 2 min, all disappear again. |
03-30-2002, 08:38 | #4 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Ukraine Age: 48
Member: 8779 Status: Offline Thanks Meter: 1 | For doctorvatson: Changing capacitor (nearest to display connector) you can't solve your problem. You must replace it to another one with 2-3 times bigger capacitence. I tried this solution and it's working perfect. Thanks for attention. Sonia. |
03-30-2002, 21:37 | #6 (permalink) | |
Freak Poster Join Date: Jan 2001 Location: Russia, Moscow Age: 51
Member: 2951 Status: Offline Thanks Meter: 4 | for Sonia Quote:
Спасибо | |
03-31-2002, 00:14 | #7 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Ukraine Age: 46
Member: 7767 Status: Offline Thanks Meter: 3 | To Dmitry Erokhin: If You want to know the capacity of display's capacitors, mail to Vicky and exchange with him (he worked very hardly with this problem ). I can give You small solution: work little like Sonya and You'll get a good results. It's not so hardly. I think, Sonia will agree with me. Last edited by Chuk; 03-31-2002 at 20:06. |
03-31-2002, 00:56 | #8 (permalink) |
Member: 5889 Status: Offline Thanks Meter: 0 | to Sonia I replaced capasitors as You say - If hold message box open 2-3 min problem will stay. May be there are no reasons to hold box open 3 min ,but if ... Thanks |
03-31-2002, 17:12 | #9 (permalink) | |
Member: 2951 Status: Offline Thanks Meter: 4 | Quote:
Будь у меня под рукой измеритель емкости, я бы здесь никого не спрашивал, а самбы заменил. К сожалению его у меня нет. Спасибо, что выслушал. | |
03-31-2002, 20:20 | #10 (permalink) |
Member: 7767 Status: Offline Thanks Meter: 3 | Sorry for non english, it's for Dmitriy Erokhin with best wishes: 1. Это не письма, а форум. И не чужие, а общие. 2. Читай старые посты (очень полезно) и ты найдешь номинал, если это поможет. 3. Тут не сервис центр Нокии, чтобы знать номиналы "по паспорту". Если тебе интересно, как нашли этот глюк - взяли и впаяли емкость чуть большего размера. Тебе дали идею, а ты ей не можешь воспользоваться. Не факт, что она одинаковая для всех дисплеев. Хочешь быстро делать - меняй дисплей, надежнее. 4. Пиши по английски, а то многие не понимают! Last edited by Chuk; 03-31-2002 at 20:34. |
03-31-2002, 22:18 | #11 (permalink) |
Member: 8779 Status: Offline Thanks Meter: 1 | Sorry for non english. For Dmitry Erokhin: Насчет измерителя емкости - любой современный более-менее приличный цифровик меряет емкость. Тебе достаточно подпаять к контактам два провода как можно меньшей длины чтобы не вносить паразитку (емкость там небольшая). И насчет конечного solutiona для твоей проблемы: все равно рано или поздно эти долбаные дисплеи дохнут. Так что я поторопился с выводами и приношу свои извинения. Сегодня придется еще помучиться. For all in this topic: I think that the checked solution is replacing of damned display. Or Vicky knows something, but he is very serious man and his solution cost VVVVEEEERRRRRYYYYY MUCH! Regards. Sonia. |
04-01-2002, 00:21 | #12 (permalink) | |
Nokia 8210 - Black Screen of Death? | mixsingh | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-17-2004 20:13 |
8210 blank screen when u try to use inbox! | AE177 | Nokia Hardware & Hardware Repair | 9 | 07-17-2003 22:02 |
8210 charge problem. Repair solution | Pk2GSM | Nokia Hardware & Hardware Repair | 0 | 11-19-2002 16:56 |
Nokia 8210 blank screen when new message received. | monie | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-06-2002 15:04 |
8210 Blank Screen | gurmk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 02-19-2002 16:29 |
