8210 restart it self my 8210 when you open it it have no signal and restart itself every 10 sec. after 2-3 restarts it found signal and works perfect i have upgrade it ,change imei ,calculate faid but nothing please help:( :( |
Re: 8210 restart it self Mix00, 1:Check at your C165 . 2:and try to adjust output level lower , and clean your battery connect pin / battery connector ! 3:reball cobba, and try to fine any rusty in cobba bga pad 4:replace 26Mhz TCXO Willy Quote:
nice solution willy, you're "nokia master" ................. |
Hello Hary, thanks for praises, i just do what i can do,, and i hope all mate to help all members ! to share some good information! thanks again ! Willy Quote:
thanks willy you are the best!! |
Hello Mix00 thanks ! for pass time,, i have some 3310 and 8210 phone, which same problem ,, when i test phone on test jig,it work well , i did also swap board to others casing for test phone, and it working good too, final,, i saw battery connector ,, which part connect to PCB, it was scorch , and curved, then lost resilience ....... maybe this information can help you a bit :) Willy |
hallo willy!! now i change c165 and i will check batery conector. if no result i will go to other steps thanks |
