03-02-2003, 20:44 | #1 (permalink) |
No Life Poster Join Date: Nov 2001
Member: 7352 Status: Offline Thanks Meter: 13 | 8210 water damage light |
03-03-2003, 00:07 | #4 (permalink) |
Freak Poster Join Date: Jul 2002 Location: Croatia Age: 49
Member: 14004 Status: Offline Thanks Meter: 6 | chek the LEDs first You can easily check the LEDs with some power supply (3V). But, in your case, they are probably OK, you have some lines on board damaged. Use service manual, and check these lines (they go from UI chip located on the sams side as LEDs, on the top right). |
03-03-2003, 23:00 | #6 (permalink) |
Freak Poster Join Date: Feb 2001 Location: South Africa
Member: 3355 Status: Offline Thanks Meter: 1 | Easiest way without a manual is to get a hold of a working 8210 board. Then trace the tracks between LED's and UIF chip on working board using a multimeter (set it on continueity mode). This way you can see which tracks are broken on your H2O damaged phone. Then you just bridge the broken tracks and Voila! I hope this helps! Its easier to do than to explain. Good Luck |
1600 water damage light pro | Hitesh manocha | Nokia Hardware & Hardware Repair | 6 | 07-16-2009 06:00 |
8600 Water damaged.Lights always on! | Uvedovle | Nokia Hardware & Hardware Repair | 0 | 11-18-2008 17:26 |
8210 water damage. key 1, 4, 7, * not function | Ian | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-12-2004 22:42 |
8210 water damage can't switch on but... | dragories | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-29-2002 18:31 |
8210 Water damage | Beef | Nokia Hardware & Hardware Repair | 0 | 01-12-2002 21:24 |
