8250 "Not Charging" now completely dead.. This phone shows "Not Charging" when charger is connected. I rehot the charging IC and now the phone is completely dead. Appreciate any comments. |
Hi azampk, Thanks for the your help. I have removed the Charging IC and try to on the phone but still not on. Is it possible to switch on the phone without the charging IC? thanks |
i think that u overheat the cpu... it hapend with me once |
Your MAD probably faulty, Rehot, but not too hot |
If you have touched the cpu while rehoting the charging ic then it must be him.but I sugest you to change the diode under the ccont (v 212) I think that is writen on her,or check if you flow out some smd by the cpu.post if there is change and if it hasn't changed nothing br |
