08-13-2005, 15:54 | #2 (permalink) |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | First thing you should do in case that charging of battery is not possible is to run energy management calibration. Note that calibration only works with JBV-1. In Service jig it is not possible because of missing bottom connector I009. Also check whether charging is only from time to time not possible or if charging does not work permanently. In case that faut appears from time to time only, especially check spring contacts of bottom connector I009 and battery connector X101 if bent, soiled or corroded. Also make sure that contact pads for bottom connector on PCB are clean. if necessary clean PCB with an appropriate amount of alcohol. Do not use any scratching or rubbing tools! To ensure function of the phone run energy management calibration whenever a part has been changed in the charging circuit! I009, X101 - check mechanical appearance of battery connector and bottom connector, change parts if bent, soiled or corroded. F100 - check resistance of fuse. Must be 0Ω V100 - check that V100 does not cause a short circuit to ground. Resistance of VCHAR-line to ground normally is ~ 2.8kΩ D200 - due to the missing possibility of rewriting IMEI and Simlockdata after changing UEM D200 it is not useful to change this part at the moment. Best Regards pazeth |
08-13-2005, 17:21 | #3 (permalink) | |
Freak Poster Join Date: Aug 2005 Age: 42
Member: 168346 Status: Offline Thanks Meter: 20 | please give me colour pic dear , kindly send me jumper in colour pic becoz i don,t understand this pic. thanks Quote:
08-13-2005, 18:53 | #4 (permalink) | |
Member: 74519 Status: Offline Thanks Meter: 79 | Quote:
here you picture | |
Motorola v501 Charging problem need charging ways or schematic | mine4ever | Motorola Hardware Repair | 0 | 03-08-2010 06:12 |
c170 charging ways ..urgent. any one know. charging way ????????????? | RATHNAMOBILESS | Samsung Hardware Repair | 1 | 03-07-2010 15:01 |
3110c charging not show plz charging way needed | mobiletuch | Nokia Hardware & Hardware Repair | 4 | 12-16-2009 15:24 |
lgKG300 charging print loss any charging ways | shani72 | LG Hardware Repair | 2 | 11-06-2008 14:26 |
>>>X600 CHARGE WAYS AND FULL CHARGING IN FEW MINUTE<<< | laboratory_gsm | Samsung Hardware Repair | 19 | 12-11-2006 01:49 |
