12-16-2002, 05:08 | #2 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: 8310 dead after dropped on ground Ryu, Check all system clock, if 26Mhz and 32.768khz all ok then you have to reball flash rom , and flash phone ! Willy Quote:
12-16-2002, 07:47 | #3 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Uranus Age: 53
Member: 5072 Status: Offline Thanks Meter: 91 | There is of course a possibility that the Power IC has become dry contact after the fall...do this.... Without LCD ..try to switch on the set applying pressure to the power ic...if it does not switch on ..then try twisting the PCB a little and pressing the power button at the same time)) if the set switches on ..then you are confirmed that the Pow IC is dry and you can re-flow. |
motorola L6 dead after falling on ground | matrix123 | Motorola Hardware Repair | 5 | 06-03-2007 19:14 |
d600 dead after drop on road | HUM | Samsung Hardware Repair | 8 | 05-28-2007 00:09 |
nokia 8310 no signal after dropped on ground | pippone67 | Nokia Hardware & Hardware Repair | 2 | 04-17-2006 15:13 |
T 300 Dead After Drop Into Water! | BANTUGBRO | Sony Ericsson | 5 | 01-07-2004 11:12 |
A300 dead after drop. Reflowed, still dead | Blartiartfast | VLSI, Conexant, Skyworks and Old Models | 0 | 11-11-2002 19:23 |
