Old 07-28-2003, 01:06   #1 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 268
Question 8310 powers up when battrey is inserted and wont power off normally
hi mates.
Got this one and am meeting this problem quite frequently now.
I checked the power switch and also for any shorts but there seems no shorts are present.
When the power switch is pressed it is as if nothing is pressed.. To switch it off have to remove battrey. Otherwise the phone works 100% ok.
any ideas or experieces pls?
thanks
al
Old 07-28-2003, 10:54   #2 (permalink)
Pandemonio100's Avatar
Member: 3381
Thanks Meter: 1,171
But this phone is fall in water?
Old 07-28-2003, 12:10   #3 (permalink)
Member: 11325
Thanks Meter: 268
ah yes sorry i forgot to include that (seems you met this problem then )
know the source of the problem??????????
thanks
al
Old 07-28-2003, 12:19   #4 (permalink)
Member: 3381
Thanks Meter: 1,171
Yes sure i have resolved this problem whit Cleaner machine and good liquid for remove oxid and clear line.
Old 07-28-2003, 15:11   #5 (permalink)
Member: 11325
Thanks Meter: 268
over a particular BGA chip or over the whole board?
thanks m8
al
Old 07-28-2003, 16:11   #6 (permalink)
Member: 3381
Thanks Meter: 1,171
No all board, put this in a cleaner machine and use good cleaner or a liquid that you have tested for remove oxid from board, make this for 2 or 3 time, and after if problem persist you have to change some chip broken but you have look first what chip are more oxidized. That all.
Old 07-28-2003, 20:45   #7 (permalink)
Member: 11325
Thanks Meter: 268
thanks mate
i ll try it out
however if it is the UEM i l lelave it as it is. Not worth risking it since it works ok as it is except it wont power down.
al
n93 hangs at nokia logo when sim is inserted but without sim,works normally GOODNESS Nokia Hardware & Hardware Repair 3 07-22-2007 17:41
k700i hangs up when simcard is inserted planetgarapata Old Ericsson Phones & Sony Phones 3 05-15-2006 16:53
5100 power on by itself when battrey is inserted... Burnt Cobba Nokia Hardware & Hardware Repair 3 10-04-2005 16:17
6600 powering on by itself when battrey is inserted.... switch has no effect at all Burnt Cobba Nokia Hardware & Hardware Repair 4 04-11-2005 19:51
GD90 when battrey is inserted starts charging Burnt Cobba Panasonic 5 07-02-2003 00:10
Page generated in 0.17075 seconds with 9 queries
