Old 07-02-2004, 11:31   #1 (permalink)
.:::Dr. Cell:::.'s Avatar
Member: 48857
Thanks Meter: 31
Nokia 6610 signal drop
Hi i have a problem with 6610 which drops signal. should i change its Pa or there can be other solution too. and which Pa can i replace with old one.
Thanx in advance
Old 07-02-2004, 11:48   #2 (permalink)
Imran_Khatri's Avatar
Member: 56561
Sonork: 100.114006
Thanks Meter: 41
check...
First write PM file then do full factory Default. and if not worked then full FLASH the Phone,,,,MCU+PPM+PM then DO full Factory default....Hopefully worked...
WBR
Imran Khatri
Old 07-03-2004, 12:22   #3 (permalink)
Member: 71309
Thanks Meter: 5
6610 ne prob..
First write PM file then do full factory Default. & check PA supply only
Old 07-03-2004, 17:57   #4 (permalink)
Member: 31028
Thanks Meter: 56
also check ant.switch
Old 10-23-2004, 12:33   #5 (permalink)
Member: 48857
Thanks Meter: 31
nothing worked for me. plz suggest other solutions. As i power on the set after some time signal comes at ones with the network but drops after some seconds. plz help
Old 10-23-2004, 12:50   #6 (permalink)
Member: 63385
Thanks Meter: 3
If not Software den do hardware repair... Try Reheat Helga, dats d culprit for 6610 drop signal... Post result...
Chill!
Old 10-23-2004, 14:39   #7 (permalink)
Member: 79725
Thanks Meter: 5
hi
u have to check the tow crystal 26mhz and te 32khz
this is the most important thing in signal drop
Old 10-24-2004, 12:09   #8 (permalink)
Member: 63385
Thanks Meter: 3
Yeah crystals may cause drop signal but seldom... Helga or PA or Antenna Switch usually causes drop sicgnal...
Chill!
Old 01-15-2005, 14:47   #9 (permalink)
Member: 48857
Thanks Meter: 31
ok i will check that solution too and will post results as soon as i will try
Old 01-15-2005, 17:51   #10 (permalink)
desmond2727's Avatar
Member: 58704
Sonork: 100.1618753
Thanks Meter: 43
Thanx in advance
Hi mate that 6610 PA jst same like 7210 cant ather PA..
nokia 7610 signal drop plz help graceful2 Nokia Hardware & Hardware Repair 2 03-03-2009 14:45
Nokia 6030 Signal drop and power off after few second Munir Memon Universalbox 3 07-21-2008 11:42
Nokia 7210. Signal Drop.. Water Damage?? DrMobile Nokia Hardware & Hardware Repair 5 09-02-2004 08:17
Nokia 3330 signal drops to zero jeanfleur Nokia Hardware & Hardware Repair 8 02-15-2004 14:20
Nokia 8210-8850 drops signal tgsm Nokia Hardware & Hardware Repair 2 03-16-2003 20:27
Page generated in 0.37684 seconds with 9 queries
