Old 09-09-2006, 16:26   #1 (permalink)
jab
Member: 12386
Thanks Meter: 18
8800 no back lcd lights
hi all, have nokia 8800 liquid damage with no back lights. tried new complete lcd still the same. any one any solution on hardware.
Old 10-01-2006, 01:13   #2 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
8800 no back light
jab ,
dear u not told that key pad light are on , if they not on , then u should check dc to dc converter , there are light coil is faulty
Old 10-03-2006, 14:59   #3 (permalink)
jab
Member: 12386
Thanks Meter: 18
salam nadeem bottom keypad lights are on but no lcd lights
Old 10-03-2006, 21:35   #4 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
walikum asslam , happy ramadan , jab
there is ur solution by pic , mostly light IC has damage , but some time light coil damage too ,light coil has 32 turns , u can rewind its if it damage, its consist of dust core and magnet and 32 turn of copper wire , post result any more service for me ,
Old 10-03-2006, 21:40   #5 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
8800
, so thats not ur prob , ur prob is in the flex , bcoz key pad light is on , but flex not give the volt to LCD of LEDs ,mostly it has damage ,
Old 01-10-2007, 04:27   #6 (permalink)
Member: 51838
salam
how can i know coil is damaged?
can use avometer
Old 02-19-2007, 02:43   #7 (permalink)
Member: 153584
Thanks Meter: 4
i have this problem - the keypad lights and you can hear the nokia sound to start the phone but the lcd does not light, how can i change the flex and where can i get the flex cable
Old 02-19-2007, 13:05   #8 (permalink)
Member: 103401
Thanks Meter: 3
Try to repair water damages of your flex. You need microscope and steady
hands. You will see broken links. Try to restore them. B.R.
Old 02-19-2007, 13:15   #9 (permalink)
mhamad-198's Avatar
Member: 437340
Thanks Meter: 35
thanksssssssssssss.......
Old 03-09-2007, 00:46   #10 (permalink)
Member: 223710
Thanks Meter: 246
Its H/W foult. check display IC.
Old 07-03-2007, 04:12   #11 (permalink)
Member: 146818
Thanks Meter: 7
i have same problem, but my one's flex is good, because i tried with another working 8800, anything works fine, but all ic on borad are sealed, so i think that is display ic problem
6680 no keypad/lcd light dizzu Nokia Hardware & Hardware Repair 8 12-22-2011 14:30
6300 no led lcd light ADNAN_XXX Nokia Hardware & Hardware Repair 5 07-18-2009 19:30
P400 no back light on Lcd screen kelvinlim Samsung Hardware Repair 10 05-06-2006 18:12
V200 no back light in LCD ! GSM SNIPER Samsung Hardware Repair 1 03-17-2005 16:46
T720g Cingular flashed but no exterior LCD Light activegsm Motorola P2k 5 07-27-2004 16:50
Page generated in 0.26068 seconds with 10 queries
