01-11-2002, 10:41 | #1 (permalink) |
No Life Poster Join Date: Apr 2001
Member: 4270 Status: Offline Thanks Meter: 13 | 8850 doesnt hold power,cuts off during calls!!! can some1 plz help me, i have an 8850 that does not hold power, whenever u call out it looses all battery power even though the battery is full. your help will b highly appreciated. regards<br />reo <img src="smile.gif" border="0"> |
01-13-2002, 12:45 | #6 (permalink) |
Junior Member Join Date: Dec 2001
Member: 8041 Status: Offline Thanks Meter: 0 | for poor batt. life - <br />check batt. connector ok, ONLY 1 pin offset from the 4! adjust tx power levels if possible! ideal values given in manual & if hav access to rf tester, adjust co-efficients accordingly.....<br />IF tx values low on tester, then change pa....<br />for switch off-<br />clean batt. pads as mentioned & reflow ccont |
01-18-2002, 16:38 | #9 (permalink) |
Member: 4270 Status: Offline Thanks Meter: 13 | HI guys unfortunately, the phone still does the same thing after i changed the PA and battery pins. is the any other way to repair this ? regards<br />reo <img src="confused.gif" border="0"> |
05-30-2002, 21:44 | #11 (permalink) |
No Life Poster Join Date: Jun 2001 Location: www.microera.si
Member: 4923 Status: Offline Thanks Meter: 74 | My 8850 was in water! I have on BAT pins 92 Ohm resistance. I search true +BAT wires and I think that is N101 in fault! Is this possible? VIBRA chip is OK! I remove it and still 92 Ohm on +BAT pin!! 8850 work OK only battery life is aprox. 8 hours! (because 92 Ohms on BAT pins of course..) Best regards, |
Alcatel BE4 Turn off during call | 43e08 | Alcatel TCL Hardware Repair | 6 | 05-01-2008 05:25 |
Power cut off during update | dferry_ie | DreamBox | 3 | 03-03-2008 13:52 |
7650 turn off during call | c_ahmad79 | WD2 & APE (Symbian Phones) | 2 | 10-20-2006 21:25 |
switched off during call | segun | Nokia Hardware & Hardware Repair | 1 | 05-03-2005 06:51 |
my 8210 switches off during call | hydroman28 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-06-2004 03:28 |
