02-25-2003, 04:34 | #1 (permalink) |
Freak Poster Join Date: Nov 2000 Location: Croatia Age: 47
Member: 2466 Status: Offline Thanks Meter: 10 | 8850 Full Signal, but can't make a call After few minutes it works normaly again, and then few calls later loses signal again or just can't make a call but have full signal When it have full signal but can't make a call, I try to search network manually, find network ok, and logon to network ok. When it loses signal and I try to search network manually, after long time find network ok, but have NO ACCESS message (PA is new) I rehot all pcb, change PA and antena switch, but nothing. What to change now, cobba, hagar, ccont, christal, resistors near PA,...? |
02-26-2003, 20:45 | #4 (permalink) |
Moderator Join Date: Sep 2002 Location: Serbia/Hungary Age: 42
Member: 15994 Status: Offline Thanks Meter: 263 | Look your cobba id in nk_calc if it is 00000 there is a problem. But I think it is the power amplifier.... it is located next to the antenna switcher |
02-27-2003, 20:03 | #7 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 51
Member: 3194 Status: Offline Thanks Meter: 41 | Check quality of conection between antenna and PCB. ( You can try to push it hard when making a call ) If u can call succesfully, it seem u have bad connection. Usually, change the frame will solve the problem. hope help |
03-01-2003, 04:34 | #9 (permalink) |
Member: 2466 Status: Offline Thanks Meter: 10 | My problem is in controling of antena switch! When I put new 100% working PA and antena switch (I tested on other phone) I still have this problem with loosing signal but when I remove antena switch and just connect 3 points of antena switch with wire my phone is working normaly. I want to know if it is bad for phone to work without antena switch, only with bypass? I heard that it is bad for PA. Is it truth? And how is controled antena switch? I think this is my problem. |
03-01-2003, 04:53 | #10 (permalink) |
Freak Poster Join Date: May 2002 Location: egypt Age: 46
Member: 11466 Status: Offline Thanks Meter: 0 | ok man i am glad to konw that some one say that it is bad but.. i think that no bropleme if u do that couse if u make a connection u will have anttina and u haven`t anttena swich i mean u convert yr (anttina swich ) to (anttina ) some body correct me if i wrong best regardes |
huawei c210e full signal but can't make a call ! | juwanapati | Various CDMA/TDMA Cell Phones | 0 | 11-10-2008 10:30 |
2112 signal ok but can't make a call | sl45ind | Nokia CDMA | 7 | 01-15-2007 19:55 |
3310/6210 Full Signal But Can't Make Or Receive Calls | Black-Axe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-09-2002 17:53 |
MITSUBISHI MT230 Full Signal But can't make or recieve calls | hooi76 | Hardware Repair by brands | 1 | 12-13-2001 16:08 |
savvy full signal but couldnt make a call and sms :) theres more | trafix | Philips | 0 | 09-10-2001 20:28 |
