10-02-2003, 16:15 | #1 (permalink) |
Guest
Posts: n/a
Member: | 9210 flash chips? Tried few griffin boxes, cables, etc, and nothing, i get error 5C:FFFFF(many of these)C1 It erase flash, and stops on ~5% after start flashing MCU. Phone was working before, but it just needed other language than german. There is no chance to flash it now, (no matter if i use other boxes) so i can assume i have dead flash chip inside. So, please, who can tell me what should i use in this case? What flash should i change, and from which phone i can use it? There is 3 intel flash chips. |
10-02-2003, 19:37 | #3 (permalink) |
Administrator Join Date: Jan 2001 Age: 52
Member: 3188 Status: Offline Thanks Meter: 2,394 | Do u Think GsmForum started to goes like this ! U need to Pay for Information !? U Offered Free Codes for Motorola last days, so do u think we started to Pay for Information and should get Free Codes any way. try to test with another Flasher first and let me know plz the Version of Fia Files u use! and ur Flash ID (as u said It goes till 5% so this mean u can read Flash ID) BR AboAli |
10-02-2003, 21:09 | #4 (permalink) |
Guest
Posts: n/a
Member: | check this picture: www.legija.net/tmp/DSCF0030.JPG I've tried with diferent tia files, but allways same error message in grifin. I am almost sure this is HW problem, i've reballed one of flashes, but same again. |
10-02-2003, 22:13 | #8 (permalink) |
Guest
Posts: n/a
Member: | So, did you read all i've writted ? Of course i've tried in all modes, with both of my PC-s, with few other boxes, few other cables, and so one. I need HW solution, i think i must replace one of the flash chips, only problem is which flash chip contain emulated eeprom. Becouse i am not sure how can i write new eeprom. |
10-02-2003, 22:25 | #9 (permalink) |
Registered User Join Date: Jun 2001 Location: x
Member: 4989 Status: Offline Thanks Meter: 13 | But didn't see you said you flashed phone in "SAFE" mode !!! I got same error and problem with one 9210i, but for me it worked after may retries !!! I guess Griffin was not so good developed for 9210(i) as you can see if you plug battery from Griffin, you get only 3 bars on battery indicator, and you might not get enough power at writing flash process !!! |
10-02-2003, 22:39 | #11 (permalink) |
Member: 4989 Status: Offline Thanks Meter: 13 | Here how it went that 9210i I told you about it. I tryed on PIII at 667 first, phone killed, tryed again and again but same error on flashing. then I move to my next comp, PII at 400, and here after 5 or 6 attempt, it worked. If you indeed have bad flash chip, you'll need to copy eeprom from it with labtool and put it the other flash that you replace with. |
10-03-2003, 08:36 | #12 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | Quote:
P.S. i still have the dead 9210 lying in my office Drawer. WBR Syed | |
10-03-2003, 22:21 | #13 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Uranus Age: 53
Member: 5072 Status: Offline Thanks Meter: 91 | i have had 2-3 9210's killed with Griffin........working phones ....customers came to me with certain software corruptions....i flashed them ...and during the process "error" After that i found that they were giving and error at exactly the same place while writing the MCU. I also would like to add .....that i have found that ...increasing the voltage of the power supply to the griffin box ....helps sometimes.....i have had 9210 's of late ........giving me erroe after error .....but if i adjust the voltage of the power supply of Griffin it usually helps. anyway ....@ legija if you want the PCB of a working 9210 ....tell me .....i will send it to you . rgds |
10-03-2003, 23:59 | #15 (permalink) |
No Life Poster Join Date: Dec 2001 Location: London Age: 49
Member: 7939 Status: Offline Thanks Meter: 2 | Not going to help much I guess, but I flash all the 92 I get with the PC in safe mode and with 9v @1.25amps, never had any problems (PC is p3 1000 356meg ram). |
How to know a 5300b isFlash Chip SEC xxxxxxxx-ATB or Flash Chip SEC xxxxxxxx-ATD? | emicabher | BB5BOX | 4 | 10-04-2007 00:39 |
2100 new flash chip flashing with dejan v1.00b work 1000% | Siemens man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 21 | 07-13-2006 11:10 |
2100 new flash chip flashing with dejan v1.00b work 1000% solution | Siemens man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 25 | 10-16-2003 23:29 |
2100 new flash chip flashing with dejan v1.00b work 1000% solution | Siemens man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 74 | 08-21-2003 22:41 |
2100 new flash chip flashing with dejan v1.00b work 1000% | Siemens man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 23 | 08-10-2003 04:13 |
