9210 Pda Failure Hi I Have 2 pcs 9210 handsets. The GSM Phone is working fine, but the Pda fails to turn on. I have flashed both the phones,changed flex cable, change internal LCD, but nothing seems to work. Somebody please suggest what should be done. BR |
Do we have any experts to reply on this here.... |
check your placement again. bestman. |
Controll your connectors, If ok, resold MADLINDA, Flash ICs if not glued. GreetZ |
Thank you all guys for the reply. Will post you the results . BR |
I have the same problem with my 9210i rae-5 The phone working fine... I flash mcu and ppm and still the same..PDA does`n start and can`t format ! only white screen... I change the whole module from another 9210i and the display is working fine... I also reflow MADLINDA....no succes..!!! Any ideas?? Quote:
