01-26-2006, 22:24 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 36
Member: 78543 Status: Offline Sonork: 100.1603369 Thanks Meter: 25 | 7610 broken contacts from PCB Contacts from #16, 18, 19,20,21,22,23, 24 are broken from PCB so there's no way to put them back in that place. I was thinking of to tako wires and drive contacts directly from LCD to places where they should be. I've also found that they should be on Z402 , but now I'd like to know what to do? Should I take off Z402 from PCB (with hot air) and then connect LCD contacts where they should be, or is there another way to connect LCD contacts at some other place (that I don't have to take off Z402)? Hope you understand me! Thansk a lot! Best regards, Igor |
02-08-2006, 02:25 | #3 (permalink) |
Freak Poster Join Date: Dec 2005 Age: 44
Member: 214350 Status: Offline Thanks Meter: 17 | Unfortunately bith of you have no other choice , raising Z402 and make briding for every thing ! . I attatched the image of the EMIF10 chip's pinout . Still be the pin No 16's problem because it goes directly to V400 not Z402 ! |
04-11-2006, 10:43 | #4 (permalink) |
Member: 78543 Status: Offline Sonork: 100.1603369 Thanks Meter: 25 | Hm, now, i have only one more question... Is it sure to take off z402? does it have some kind of protection, maybe I shouldn't take him off? and Is it possible to connect all contacts on such small space? BR Igor |
04-12-2006, 08:04 | #5 (permalink) | |
Member: 214350 Status: Offline Thanks Meter: 17 | Quote:
and there is no more further protection as z402 is the ESD filter , but you need to use a very thin soldering tip . | |
07-10-2006, 14:52 | #6 (permalink) | |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | Quote:
i think this is the correct emi filter . you post the one use for keypad lines . | |
07-10-2006, 22:40 | #8 (permalink) | |
Thx Modz | |
5100 - SIM socket broken contacts repair | et.com | Nokia Hardware & Hardware Repair | 3 | 04-07-2007 14:29 |
7610 broken lcd what model can fit it????? | midou01 | Nokia Hardware & Hardware Repair | 3 | 06-23-2005 09:15 |
6610 with broken display contacts on PCB??? | hallo | Nokia Hardware & Hardware Repair | 8 | 05-24-2005 15:06 |
CF62 torn I2 from PCb | pali | Siemens Hardware Repair Area | 0 | 12-01-2004 21:29 |
NOKIA 8310 need UEM schematic from PCB . need one line path:( | crossings | Nokia Hardware & Hardware Repair | 0 | 09-21-2004 09:37 |
