05-16-2011, 21:00 | #2 (permalink) |
Freak Poster Join Date: Apr 2011 Location: india
Member: 1555664 Status: Offline Thanks Meter: 11 | All mobiles hard reset here........... ALL MOBILES HARD RESET HERE........... Nokia C6 Format Soft Reset - Hard Reset to Factory Settings [COLOR=**333333]How to format or reset the Nokia C6 to factory fresh default settings. This instructions below is a guide on how to reset the device. Note: This process may delete the files you installed on Nokia C6. This may only advisable if the phone experiencing frozen or hang problems, burned out by excessive use or after installing 3rd party applications. You may need to back up all important data stored on the phone before you proceed,[/COLOR] [COLOR=**0000ff]Nokia C6 Soft Reset: This will not harmed your data . Soft reset only restores .ini files from Flash ROM on board memory of your Nokia C6. [/COLOR] [COLOR=**0000ff] 1.). Dial ***7780** 2). Press Ok/Yes[/COLOR] [COLOR=**0000ff] [/COLOR] [COLOR=**ff6600]Nokia C6 Hard Reset This will delete your data and installed applications. Hard reset will fully restore your Nokia C5-03 to default factory setting. 1). Turn the Nokia C6 OFF[/COLOR] [COLOR=**ff6600] 2). Remove the battery and reinsert it back again, then Turn it ON.[/COLOR] [COLOR=**ff6600] 3). Dial this numbers ***7370**[/COLOR] [COLOR=**ff6600] 4). Then Press Ok/Yes[/COLOR] [COLOR=**ff00ff]Nokia C6 Hard Reset through button combination. 1). Turn the Nokia C6 OFF[/COLOR] [COLOR=**ff00ff] 2). Pull out the battery and reinsert it back again, then Power it ON[/COLOR] [COLOR=**ff00ff] 3). Simultaneously press and hold *+3+Call Button (green/ok button) [/COLOR] Report Post Digg this Post!Add Post to del.icio.usBookmark Post in Technorati Reply With Quote |
05-16-2011, 21:01 | #3 (permalink) |
Member: 1555664 Status: Offline Thanks Meter: 11 | Nokia E72 Hard Reset with button combination This is a procedure on how to hard reset the Nokia E73 through button combination. Please Note: The result of this process will wipes the entire phone memory and settings fresh to how it was (or should be) when you bought it.You are advise to make a back up of your device and you need to understand that what you are doing this is at your own risk. However, this does not delete all the data stored on the memory card. Restore Factory Settings Dial *7780** to restore all the settings to default. It will request for security PIN, the default code will be 12345. Reformat Phone System Dial *7370** to reset Nokia device, only data in System will be affected. To play safe, back up all your data before proceed. It will request for security PIN, the default code will be 12345. For Hard Reset: This also restore your Nokia when it frezzes at the nokia screen logo only and didn't go any further. hard reset is an options but will result to loosing all settings, contacts, data etc… Turn your phone off and simultaneously press these four buttons circled in red. * * (asterisk key) * 3 (numeric 3 key) * CALL / GREEN key * On button This is another method below found out by trial and error when the * + 3 + Call didnt work. Switch your phone off. Then, lay it down on a flat surface With 3 finger of one hand, keep pressed shift, space bar and back space all at the same time With one finger of the other hand, press the power on button Do not release neither the 3 keys nor the power key till you see the nokia shakehands animation. __________________ |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
All 4 locks on 6110 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 04-19-2010 02:44 |
i can unlock all nokia 5110/6110/6150 | spterminator | Main Sales Section | 0 | 07-30-1999 03:05 |
all for GSM: http://fly.to/spear | spear | GSM Mobile Links | 0 | 07-11-1999 22:01 |
