Old 03-08-2011, 17:17   #1 (permalink)
bablu333's Avatar
Member: 1495471
Sonork: 1603910:abubablu
Thanks Meter: 1,582
nokia n85 low bettry solution need
when incoming call after low bettry
solution need any idea ...............
Old 03-08-2011, 17:42   #2 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 404
cheek out there is any shoartege?
if not then rehot pf post result
The Following User Says Thank You to GSMTURBO For This Useful Post:
Old 03-10-2011, 08:17   #3 (permalink)
bablu333's Avatar
Member: 1495471
Thanks Meter: 1,582
Old 03-10-2011, 12:27   #4 (permalink)
Member: 669546
Thanks Meter: 19
check board condition if short or leakage remove power ampr
or remove speaker or check speaker path
The Following User Says Thank You to arunaneesh For This Useful Post:
Old 03-12-2011, 17:58   #5 (permalink)
bablu333's Avatar
Member: 1495471
Thanks Meter: 1,582
Old 03-12-2011, 18:47   #6 (permalink)
Sagitarious's Avatar
Member: 615730
Thanks Meter: 256
Brother only change the Charging IC (Betty), your set will be ok.....
The Following User Says Thank You to Sagitarious For This Useful Post:
Old 03-12-2011, 21:57   #7 (permalink)
bablu333's Avatar
Member: 1495471
Thanks Meter: 1,582
are you tested???????????????????/
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.16234 seconds with 9 queries
