asha 200 no network coverage fault i need help i have this set water damaged ans was shorted i removed the capacitor close to pa phone now work, but there is signal but refuse to go calls. i have changed pa and filters no way. pls i need help. |
1 Attachment(s) ur set was water damage so some things need to be checked. if u post here selftest result that would be better . anyway first check or replace vbat supply coil to PA , check or replace L7707 (marked in picture) if vbat supply to ok then replace 26mhz clock crystal & check . if still same then u need to reball or replace x-glod cpu . post result here. |
