10-16-2012, 11:11 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Faisalabad, Pakistan Age: 41
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | ASHA 200 Only keypad light Kind regards, Vicky |
11-02-2012, 08:56 | #3 (permalink) |
Junior Member Join Date: Jun 2011
Member: 1590305 Status: Offline Thanks Meter: 2 | I have same problem set ok....... u just flash in dead usb with mx box........ thank you........ MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], Using device: USB Phonet and HTI, FW ver: 00.50, SN: 000016E9 Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: nmwcdnsuc, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.46 EBL version: Quantum_Bootloader_10.46_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Waiting for USB device removal ...Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 34EF645D Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 34EF645D Verifying communication to device OK. Verifying communication to device OK. Phone type: RM-761 (Nokia 200) SW version: V 11.56 26-03-12 RM-761 (c) Nokia Imei plain: 35934704941458-6 Product code: 059J4K8 Battery voltage: 3766 mV, current: 26 mA Cellular system: GSM ASIC ID: 0x0000, type: 11 Ppm Id: MH2 Language Pack: - not available. Camera config: 094B2F01009021, ver: Imei net: 35934704941458 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Phone type: RM-761 (Nokia 200) SW version: V 11.56 26-03-12 RM-761 (c) Nokia Imei plain: 35934704941458-6 Product code: 059J4K8 Battery voltage: 3766 mV, current: 23 mA Cellular system: GSM ASIC ID: 0x0000, type: 11 Ppm Id: MH2 Language Pack: - not available. Camera config: 094B2F01009021, ver: Imei net: 35934704941458 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Nokia USB ROM disconnected. thank you |
The Following User Says Thank You to vinuneo For This Useful Post: |
11-06-2012, 05:03 | #4 (permalink) |
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | @hongnhanzzn where I can found this IC and what is function of this ic? I not have other ASHA 200 board for this ic to replace. When I attach phone with USB cable for flashing then my pc hanged and phone's keypad light also off and when remove USB cable then pc work again normal and phone's keypad up again so it short and hardware fault so post working solution |
06-27-2013, 09:22 | #6 (permalink) | ||
Freak Poster Join Date: Jul 2008 Location: Iran.ahar
Member: 811264 Status: Offline Sonork: 100.1638656 Thanks Meter: 231 | Quote:
I have same problem .......... ASHA 200 when insert battery keypad light on but no power up. | ||
06-27-2013, 12:48 | #7 (permalink) |
Registered User Join Date: May 2008 Location: ...::IsLam::... Age: 39
Member: 767472 Status: Offline Sonork: 100.1609877 Thanks Meter: 599 | Setup By Setup Full charge battry insert then check Flash with latest verion Remove Camera same time Resold Main Power Ic + Flash Ic |
The Following User Says Thank You to .....::::GsmAdeel:::::..... For This Useful Post: |
