07-05-2008, 09:59 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: every where
Member: 761110 Status: Offline Sonork: 100 0911 Thanks Meter: 45 | battery empty 1100 i have 1100 when i call from this phone battery goes empty. i chek with one other battery but still same. any body help me thanks in advance. |
09-07-2011, 07:42 | #13 (permalink) |
Freak Poster Join Date: May 2011 Age: 59
Member: 1587321 Status: Offline Sonork: 100.1607684 Thanks Meter: 10 | Nokia 6500c Charger not supported problem Hello brothers, I have 6500c , which has micro usb type charger, when I connect charger it is charging well, after some time ( 5 minutes ) screen shows : " charger not supported ". Please help me to solve this problem, Thanks. |
09-07-2011, 08:11 | #15 (permalink) | |
Insane Poster Join Date: Apr 2008 Location: Sri Lanka
Member: 741012 Status: Offline Thanks Meter: 20 | nokia battey emty Quote:
when you check use current control turn to full 2.0A and voltage 4.2 2. if your power supply ok phone will on and it can get a call. if your Phone ok consumption current should be Les than 60 if higher than 90 PA is bad. you have to change it but i see lot of battery are not good so that fault come from battery so first check by original battery | |
nokia 1100 battery empty problem help me | alkesh02 | Nokia Hardware & Hardware Repair | 5 | 12-06-2015 15:01 |
1100 nokia says battery empty and phone offs | gsmwiz | Nokia Hardware & Hardware Repair | 10 | 09-05-2012 08:35 |
1100 Displays Battery Empty | JIMMY092372 | Nokia Hardware & Hardware Repair | 13 | 09-04-2012 13:56 |
1100 battery empty | dipingeorge | Nokia Hardware & Hardware Repair | 3 | 09-04-2012 13:54 |
Battery empty, Bosch 509, but the battery is still full | calinsand | Various | 7 | 07-25-2004 00:20 |
