02-25-2008, 13:06 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 46
Member: 138020 Status: Offline Thanks Meter: 87 | BB5 Engine Structure ENOS = EPOC(Symbian OS) + NOS(Nokia OS) ENOS based products -> 3650, 6600, 9210 … EPOC and NOS operate mostly independent Both operating systems are executed on the same core – they use the same common memory devices and resources CMT-APE (NOS-EPOC) communication based on Phonet protocol On execution NOS tasks have always higher priority NOS is mainly focused on cellular modem activities (RF, powers, …) EPOC is mainly focused on user interface activities Dual Engine Structure Dual engine products –> 6630, 9500, 6680 & 6681 Both operating systems are physically separated on different cores – they have own memory devices and resources CMT-APE (NOS-EPOC) communication based on Phonet via physically bus (X-BUS) NOS is totally focused on cellular modem activities EPOC is totally focused on user interface activities |
The Following 13 Users Say Thank You to nalkershy For This Useful Post: |
02-25-2008, 13:34 | #2 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Block Diagram & Key Components Clocking Powering Up Power Up Steps After Power On RETU activates Sleep Clock, VANA, VIO, VR1 and VDRAM Voltage @ Retu RSTX pin will then enable TAHVO ASIC TAHVO enable VCORE (RAP3G) and its internal oscillator to drive VCOREA (OMAP) VCTCXO regulator is set on and RFClk (38.4 MHz) is started by RETU regulator RETU release PURX after 16 ms after RFClk is stable 2.4 MHz SMPS clock for TAHVO is produced After PURX is released and 2 rising edge of 2.4 synchronization clock is detected, TAHVO will use it to drive VCOREA System is up and running Software is used to switch on other regulators RAP3G RAP3G is a 3G Radio Application Processor Successor for TIKU (used in NOKIA 7600) with some technical improvements and additional features In general RAP3G consists of three separate parts: Processor subsystem (PSS) that includes ARM926 MCU as a main processor, Lead3 PH3 DSP and related functions MCU peripherals DSP peripherals RAP3G is running with NOS and takes care of all cellular modem activities RAP3G core voltage (1.40V) is generated from TAHVO VCORE and I/O voltage (1.8V) is from RETU VIO. Core voltage in sleep mode is lowered to 1.05V RETU RETU is the primary EM ASIC including following functional blocks: Start up logic and reset control Charger detection Battery voltage monitoring 32.768kHz clock with external crystal Real time clock with external backup battery SIM card interface Stereo audio codecs and amplifiers A/D converter Regulators Vibra interface Digital interface (CBUS) RETU ASIC does not include security functions such as UEM(E,K) TAHVO TAHVO is the secondary EM ASIC including following functional blocks: Core supply generation (VCORE & VCOREA) Charge control circuitry Level shifter and regulator for USB/FBUS Current gauge for battery current measuring External LED driver control interface Digital interface (CBUS) TAHVO ASIC does not include security functions such as UEM(E,K) CMT Flash CMT Flash memory is used to store: MCU program code DSP program code Tuning values Certificates Capacity: 64Mbit Logic and supply voltage for NOR Flash is supplied from VIO (1.8V) Flash clock is 48MHz (192MHz/4) CMT SDRAM CMT SDRAM is mainly used as a dynamic data storage for MCU data Capacity: 64MBit SDRAM core voltage (1.8V) is generated by RETU’s VDRAM regulator I/O voltage (1.8V) is generated by RETU’s VIO regulator SDRAM clock is 96MHz (192MHz/2) OMAP 1710 OMAP is the application processor running with Symbian operating system (EPOC) Platform for executing all user related application. Main interfaces: Camera interface Display interface Bluetooth interface MMC interface USB interface Keyboard interface X-Bus for communication with RAP3G OMAP is a standard ASIC designed by Texas Instruments and used also by other manufacturers of mobile phones and handheld PCs Core voltage VCORE=1.4V is generated by discrete SMPS, and is lowered to 1.09V in sleep mode I/O voltage VIO=1.8V is generated by RETU APE Combo Memory APE Flash is used to store application code and user data It is not possible to execute code directly from Flash -> executables need first to be loaded to DDR and run from there Capacity: 256Mbit (Flash), 256Mbit (DDR) Core voltage for DDR is VDRAM 1.8V VIO 1.8V is for DDR I/O voltage Both NAND core and I/O voltages are generated by RETU DDR clock is 110MHz (220MHz/2) Flash interface speed is 22MHz Product Specific Circuitries Front Camera The front camera is controlled and its data is collected by OMAP The I/O voltage of OMAP is 1.8V, and the one of the camera is 2.8V;therefore a level shifter is needed The camera is powered with two different voltages from LDO (Low-dropout voltage) regulators: VCAM 1.5V for camera digital circuits, and sensor A/D-converter VCAM2 2.8V for camera I/O, and sensor photo diode floow |
The Following 6 Users Say Thank You to nalkershy For This Useful Post: |
02-25-2008, 13:46 | #4 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Back Camera Connected to OMAP via data and control interfaces Data transfer:through differential serial interface using clock and data Camera control:bidirectional control interface compatible with I2C standard using SCL&SDA signals (1.8V) Camera digital voltage is VCAM (1.5V) from discrete LDO Camera ****og voltage is VAUX (2.5V) from RETU Additional control signals Vctrl: high (1.8V)=camera active low (0V)=camera inactive ExtCLK: clock from OMAP1710 (9.6MHz) Camera Flash Light Designed to give more light when taking pictures in dark environment The same LED is also used as an indicator light for indicating when: a video clip is being recorded a picture is taken TK1189 is the SMPS for FLED. The enable of TK1189 is controlled by two hosts: flash mode is controlled by the camera indicator mode is controlled by OMAP |
The Following 3 Users Say Thank You to nalkershy For This Useful Post: |
02-25-2008, 13:48 | #5 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Bluetooth™ Single chip BT BC3 (includes RF, BB & ROM memory) UART interface for control/data with OMAP PCM interface for audio data with RAP3G IO voltage 1.8V from VIO ****og voltage 2.85V from VBAT through discrete LDO Clock 38.4MHz from RF part |
The Following 2 Users Say Thank You to nalkershy For This Useful Post: |
02-25-2008, 13:50 | #6 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Ambient Light Sensor Ambient Light Sensor is located in the upper part of the phone and consists of: Light guide (part of front cover) phototransistor + resistor NTC + resistors RETU Information of ambient lighting is used to control backlights of the phone: Keypad lighting is only switched on when environment is dark/dim Display backlights are dimmed, when environment is dark/dim |
The Following User Says Thank You to nalkershy For This Useful Post: |
02-25-2008, 13:51 | #7 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | MMC Interface Reduced size MMC can be used to store photos, videos, etc… MMC is connected to OMAP Interface voltage level is 1.8V and power supply from RETU VSIM2 EMC protection by using ASIPs (Application Specific Integrated Passive) MMC is powered down when MMC cover is opened Cover lid open = signal connected to GND Cover lid closed = signal connected to 1.8V |
02-25-2008, 13:56 | #8 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Voltages Usage – Power Up Logic VANA RETU internal usage, Tomohawk/HeadDet-line pull up VIO Display I/O, BT I/O, Helen I/O, RAP3G I/O, TAHVO I/O, APE Combo I/O VR1 Ref. Oscillator, Ref. Clk buffer, digital blocks of HINKU/VINKU, BT’s clock buffer supply VDRAM 64Mbit SDRAM (RAP3G), 256Mbit DDR (OMAP) DCT-4 Vs BB5 power desteribution fllow |
02-25-2008, 15:05 | #13 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Power Control Loop – WCDMA Transmitter 1/2 TXC is used to drive the VGA which is used as the “main power controller” The PA outside is just for the final setting of the outgoing power WCDMA uses closed loop SW power control, where the Base Station will provide information for the terminal to increase or decrease its power by 1 or 2 dB steps Power Detection: It is required that terminal must be able to measure its output power in high power level. The power detector measure it and fed a voltage (WTXDET) back to RETU to undergo AD conversion Output power needs to be limited to +21 dBm Isolator: It passes RF power only in one direction. Without it, RF power may leak in and affect the output of the detection circuit, resulting in error in the power control Power Control Loop – WCDMA Transmitter 2/2 SMPS: The supply voltage of the PA and limits the lowest supply voltage to 1.5V. At highest power levels the SMPS output settles nominally to 3.2V The supply voltage and the reference current lines (DAC 101 and DAC 201) are used to set the PA to distortion-free gain according to PA vendor's specification; this is essential in WCDMA Synthesizers |
02-25-2008, 15:06 | #14 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Phase Lock Loop (PLL The output of the phase det depend on the phase of the measured frequency compared to the phase of the reference frequency PLL charge pump charges or discharges the integrated capacitor in the loop filter based on the output of the phase det (comparator) |
02-25-2008, 15:08 | #15 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Key Components 0f WCDMA Receiver Why do we need Additional Filtering? This SAW filter is to attenuate the Tx signal which is leaking through the duplex filter and amplified by the LNA Why do we use duplexer instead of antenna switch? This is because Tx and Rx are functioning in continuous mode in WCDMA What is the use of AGC stage? This stage is used to maintain the voltage swing at the AD converter in BB at an adequate level Power Control Loop – GSM Transmitter Power Detector Circuitry in PA gives a DC value proportional to the output power DC level is feedback to the negative input of ERROR amplifier in VINKU The DC level is then compare with the TXC reference signal The output of the ERROR amplifier is then fed to a buffer amplifier which drive the VGA Note: TXC is obtained from the network for power level control |
The Following 5 Users Say Thank You to nalkershy For This Useful Post: |
How to know Nokia BB5 Engine Structure | faisal4friend | Nokia Base Band 5 ( BB-5 ) | 1 | 07-27-2009 09:32 |
How to know Nokia BB5 Engine | zeeshanawan | Nokia Base Band 5 ( BB-5 ) | 1 | 05-31-2009 15:01 |
How to know Nokia BB5 Engine Structure | saifali | J.A.F. By Jafsupport.com | 0 | 03-25-2009 19:25 |
structure nokia bb5 | shahidsattar | Nokia Hardware & Hardware Repair | 1 | 02-24-2009 13:04 |
imei structure of BB5 | XenKo78 | Nokia Base Band 5 ( BB-5 ) | 5 | 05-18-2006 19:24 |
