Old 01-05-2008, 13:43   #1 (permalink)
Member: 644442
Thanks Meter: 11
nokia 1110,1600 and2310 insert sim
i have thi listed phones and they all display insert sim anybody with good idea
Old 01-10-2008, 21:45   #2 (permalink)
Member: 669218
Thanks Meter: 11
change their mic, charging base then check ur mobile again same then jumper sim ic ur problem solve i fully state u.
Old 01-11-2008, 05:59   #3 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
some insart sim come if back site water dameag or some is sim ic so in that case wash nicely back side and dry then check if not done then only change sim ic or make jumper..................good luck.............sopnil
Old 01-11-2008, 06:08   #4 (permalink)
king_of_rajasthan's Avatar
Member: 227647
Sonork: 100.1603662
Thanks Meter: 311
Eitheir mic, charging base is making insert sim change them then check ur mobile again if same then do jumper of sim ic
Old 01-11-2008, 07:39   #5 (permalink)
Member: 455693
Thanks Meter: 48
if it is water damage,try to clean the down side,it may solve ur problem,or make jumper to sim ic.
Old 01-11-2008, 08:37   #6 (permalink)
DIGITAL BABU's Avatar
Member: 420857
Sonork: 100.1576793
Thanks Meter: 1,734
1ST PICTURE WORK OKKKKKKK OR NO WORK
THAN
TEST 2ND PICTUER AND WORK 100% OR NO WORK
AND
3RD POGITON IS SIM IC CANGE
1110,1600,2310 insert sim problem. bravomikeghana Nokia Hardware & Hardware Repair 15 06-15-2010 18:13
1110-1112-1600-2310 insert sim new solution s.s.s.s. Nokia Hardware & Hardware Repair 3 04-22-2010 18:11
a useful solution of 1110,1600,2310 insert sim mmmfaruk Nokia Hardware & Hardware Repair 1 12-07-2009 18:38
1110,1112,1600,2310 insert sim solution m zubair Nokia Hardware & Hardware Repair 0 11-25-2009 23:05
1110,1110i,1112,1600, Etc Insert sim Solotion mobilecitycbk Nokia Hardware & Hardware Repair 7 07-28-2007 19:36
Page generated in 0.23053 seconds with 10 queries
