Old 02-26-2008, 05:12   #1 (permalink)
Crazy Poster
Member: 712168
Thanks Meter: 3
Question 3310 cant power on
i have nokia 3310 can't power on with battrey but if i use power supply in 4,5 volt, it can to power on.please help me.
Old 02-26-2008, 05:53   #2 (permalink)
Member: 547967
Thanks Meter: 653
try this
change J2 Power Diode and it will be ok press search button before posting
Old 02-26-2008, 06:27   #3 (permalink)
Member: 610864
Thanks Meter: 2
hello to our forum mate, i'm enjoying foruming with you and i'm willing to share my little tips with you but my problem is i can't insert image so that a support file can be viewed to our co-member. anyone can help me?
Old 02-26-2008, 06:32   #4 (permalink)
Member: 610864
Thanks Meter: 2
Smile
check for +line it's maybe a broken path...
Old 02-26-2008, 06:37   #5 (permalink)
Crazy Poster
Member: 712168
Thanks Meter: 3
i try to change this diode but condition is same...
Old 02-26-2008, 06:40   #6 (permalink)
Crazy Poster
Member: 712168
Thanks Meter: 3
thanks but positive line is ok.
Old 02-26-2008, 06:49   #7 (permalink)
Abussabah's Avatar
Member: 412813
Sonork: 100.1594692
Thanks Meter: 353
Replace Battery connecter, if problem still replace ccont
M A Sabah
Malappuram
Old 02-26-2008, 06:58   #8 (permalink)
Crazy Poster
Member: 712168
Thanks Meter: 3
M A Sabah
Malappuram
this condition same after change the power Ic, reball the processor, ram, and SD ram.thanks
Old 02-26-2008, 07:23   #9 (permalink)
Member: 610864
Thanks Meter: 2
by the way you have mention when u connect it to 4-5 v ps the phone is powering on...have you tried to change bat. with a new one? or try charging the phone?...make sure you have a 3.5v bat. power when charging.
Old 02-26-2008, 07:27   #10 (permalink)
Sagitarious's Avatar
Member: 615730
Thanks Meter: 256
Change the new-one Battery it will ok.....
Old 02-26-2008, 07:49   #11 (permalink)
Crazy Poster
Member: 712168
Thanks Meter: 3
batt is oke because if use batteray in another phone with same type its ok. voltage of batt is 3,8 - 4,0v. but phone can power on in 4,5 - 5 volt.thanks..
Old 02-26-2008, 09:02   #12 (permalink)
That'sme's Avatar
Member: 228871
Thanks Meter: 43
Just check whether it shows charging indications if yes then replace the power diode and if not showing then check in ufs if it turns on then see the attachment.
3310 cant power on with battery irfaN_vu Nokia Hardware & Hardware Repair 20 11-21-2008 06:49
3610 cant power on but wit power supply ok! uwenk98 Nokia Hardware & Hardware Repair 4 05-08-2004 06:01
3310 cant power on after switching off ViperGSM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-14-2004 19:34
3310 AUTO POWER ON when I put.. sifasli Nokia Hardware & Hardware Repair 1 11-05-2001 02:08
Nokia 3310 not power on after water snk Nokia Hardware & Hardware Repair 1 07-07-2001 16:15
Page generated in 0.20193 seconds with 10 queries
