c2-03 3 sec. light flash then blank screen nokia c2-03 only 3 sec. white light on screen the screen blank but key pad light ok i already flashed but still same problem. |
this is not frm flex cable .... in new flex ..same problem |
try flash................. |
i have same problem soft,flex,lcd,light component changed done but same but some times fone work normally but again light problem come |
change lcd ur problem iz solved 1000000% |
i have a same problm i change flex,lcd but not solve please help me C2-03 Nokia white display when powering on then turn to blank after 3 seconds but can make and receive calls. |
my solution 1000000000000% tested nokia c2-03 all wrong solution my solution is testd only four steep problum 100% |
nokia c2 3secend lcd light solution only four cheng orignal steep |
if u not solve after change stript try it 100% work tested in 20peace http://img19.imageshack.us/img19/743...elightandb.jpg |
This is power ic problem re hot ithttp://www.jonneale.info/9.jpg |
change the display i have tested in 2 handset |
