Old 12-25-2007, 08:54   #1 (permalink)
Member: 352189
Thanks Meter: 131
***5310-charger not supported***
my new 5310 is having critical problem. while charging (when the phone is in off-mode) charging indication showing but charging is not done. when the phone is powered on at time off charging phone disply shows" charger not supported. i tried with many new working chargers & batterys. any one help me matter most urgent..
The Following 4 Users Say Thank You to great4nara For This Useful Post:
Old 12-25-2007, 15:57   #2 (permalink)
mhamad-198's Avatar
Member: 437340
Thanks Meter: 35
bro writhe file pm .......
Old 12-25-2007, 16:51   #3 (permalink)
3lsheikh's Avatar
Member: 521296
Sonork: 100.1574136
Thanks Meter: 21
full pm file all ok.......................
Old 03-07-2008, 14:09   #4 (permalink)
Member: 51453
Thanks Meter: 729
can you share pm file for 5310?
br
Old 03-22-2008, 07:58   #5 (permalink)
Member: 187648
Thanks Meter: 4
if you write wrong pm your phon will be sim not valid
be carefull
Old 04-10-2008, 20:16   #6 (permalink)
Member: 747026
i have this exact same problem but don't know what to do, can anyone help?
ps. what is a pm file and what does it do?
cheers
Old 05-24-2008, 14:15   #7 (permalink)
Member: 627933
Thanks Meter: 7
5310 charger not supported.............................
pls help....................
The Following User Says Thank You to fizafazys For This Useful Post:
Old 05-24-2008, 22:13   #8 (permalink)
Miluk's Avatar
Member: 384541
Thanks Meter: 101
Try write PM from this link: http://forum.gsmhosting.com/vbb/show...93&postcount=5
Inside are two files: full pm without 308 and just filed 309.
If not working change charger IC
Miluk
The Following User Says Thank You to Miluk For This Useful Post:
Old 05-25-2008, 03:54   #9 (permalink)
..:::YMG:::..'s Avatar
Member: 667126
Sonork: 100.1651201
Thanks Meter: 229
change the 47k resistor...the problem will be solved
The Following 2 Users Say Thank You to ..:::YMG:::.. For This Useful Post:
Old 05-25-2008, 19:17   #10 (permalink)
Member: 627933
Thanks Meter: 7
thanks...................
Old 05-27-2008, 15:25   #11 (permalink)
Member: 647578
Thanks Meter: 25
only change the thavo ic.100% tested
Old 07-22-2008, 14:53   #12 (permalink)
aravimobile's Avatar
Member: 602589
Sonork: 0000001
Thanks Meter: 822
shame
dont say wrong information
Old 11-11-2009, 15:36   #13 (permalink)
Member: 980523
Thanks Meter: 178
plese dont post wrong info.
plz....
it's againts of
fourm RULZzZ
Old 02-24-2010, 15:04   #14 (permalink)
Member: 1017950
Thanks Meter: 7
5310 charging not supported
Old 11-15-2010, 09:05   #15 (permalink)
Member: 22316
Thanks Meter: 24
here is that you must ic
The Following User Says Thank You to gsm_dan For This Useful Post:
Solution for 1100 no response to charger/not charging yandbass Nokia Hardware & Hardware Repair 12 10-02-2010 14:05
6110 navigator not charging / charger not supported solution tested .. 6110n basilbaby Nokia Hardware & Hardware Repair 1 02-12-2009 05:46
2630 showing charger not supported when u insert the original charger GOODNESS Nokia Hardware & Hardware Repair 5 12-11-2008 12:33
6151 not charger not supported point0 Nokia Hardware & Hardware Repair 1 11-13-2007 08:15
3310 charger not accepted arslan_85pk Nokia Hardware & Hardware Repair 1 04-23-2006 11:04
Page generated in 0.30225 seconds with 10 queries
