04-11-2011, 14:25 | #4 (permalink) |
Insane Poster Join Date: Nov 2010 Location: Dhaka
Member: 1443838 Status: Offline Thanks Meter: 21 | Try to remove this ic and check: http://postimage.org/image/1twxj6hhg/ If short remain then connect with power supply then touch with your finger each and every ic and feel which become hot.. If found change it... not tasted solution... try and post your result.. |
04-11-2011, 15:04 | #6 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Cel_Phon - M.B.Din
Member: 328187 Status: Offline Thanks Meter: 1,687 | check and remove all vbat capacitors......remove mmc driver......remove bt ic even remove all components they r direct attach with main power(vbat) step by step |
04-12-2011, 12:23 | #7 (permalink) |
Junior Member Join Date: Aug 2010
Member: 1374054 Status: Offline Thanks Meter: 14 | try the image ...may be helpful to you... the parts in red block are directly connect with vbat +ve post result |
The Following User Says Thank You to bigboyb For This Useful Post: |
04-13-2011, 19:42 | #11 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | sir please chk pic when set is in short condition i remove power ic but shortage still there after remove pink marked part shortage gone it means power ic is ok |
Full Flash 5130 V05.61 | nokia_flash | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-03-2011 15:38 |
Wanted 6130 4.02 full backup Pls Read | Charly | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-06-2001 05:12 |
6150 Full Flash , Help | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-03-2001 13:34 |
Full flash for 6110 v5.24 needed | tcfx44 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-30-2001 14:04 |
NOKEY BOX FOR SALE - FULL | Zorz | Main Sales Section | 0 | 12-05-2000 10:56 |
